Audi TT 225 Quattro 2001
Old May 29, 2016 | 03:32 PM
SportMode81's Avatar
Default Audi TT 225 Quattro 2001
Hello, I'm new to the forums and don't know how things roll here. But I have a Audi TT Quattro 2001 225 and the front left has a creaking noise when driving. Is it the strut? Spring or something that just needs greasing? I can't really find where it's coming from. Thanks.
Old May 29, 2016 | 03:33 PM
And it happens a lot when it's hot outside.
Old May 29, 2016 | 03:55 PM
Mister Bally's Avatar
Standard automotive troubleshooting techniques apply. Everything else is just a guess. Especially because we are not there with the car. That's why shops charge for "diagnostics".
Old May 29, 2016 | 06:05 PM
Gotcha. It seems to go ahead when it get cool at night and when it rains
Old May 29, 2016 | 06:21 PM
The bushings on most VW & Audi vehicles have a finite life. You will need a press to R & R most of them. Some require replacement of control arms etc. You can try spray white/Teflon lube to troubleshoot (as mentioned earlier) but is a very temporary fix used to isolate one bad bushing. Only lube one, drive and listen. Then lube another etc until you find the bad one.
Old May 30, 2016 | 06:39 AM
Ok, thank you
Old May 30, 2016 | 06:44 AM
Vegas-roadster's Avatar
25 Year Member
Yeah, most likely the bushing you see when you open the hood. Very common problem. You don't say the mileage on the car. but I replaced the bushings under warranty on both my Mk 1s.
Old May 30, 2016 | 07:18 PM
mobsTTa's Avatar
Sway bar bushings. Replace, lube is very temporary fix. I think Neuspeed has them and they have a groove for the lube
https://www.google.com/webhp?sourcei...hings+symptoms
or you could try here
Audi TT Stuff: Polyurethane Bushings. I think stock are the 19mm. Check though.
 Pouria Savadkouei
 Michael S. Palmer
Old May 30, 2016 | 08:00 PM
Thanks everyone!
Old Jun 2, 2016 | 04:41 AM
Walpole5's Avatar
I just bought the same year and model and mine also creaked. Sway bar bushing, or more specifically, the plastic sleeve between the bar and the bushing. Get new poly bushings, remove the plastic sleeve and the noise will be gone. Now I have to replace the sway bar link to get rid of the clunking noise.
leeeeke
Mar 20, 2018 08:46 AM
IAM
May 5, 2003 05:49 AM
TT Hunter
Feb 14, 2003 06:05 PM
Tarmac101
13
Feb 1, 2002 06:59 AM
