Help Confiriming a Clutch Issue Please
This morning when I was leaving go to work, as usual I depressed the clutch, put my right foot on the brake, and hit the key. But when I did, the car tried to lurch forward. I released the key of course, put the tranny in reverse, and tried it again. The same thing happened, only going backwards.
I can depress the clutch and it feels fine. I can shift the car between gears with or without the clutch when the car is not running. But when it's running, it won't go into gear even with the clutch all the way to the floor.
I'm not sure where to begin trouble shooting this. My first thought was slave cylinder, but my previous experience with this kind of thing on a Miata was that the clutch would go to the floor. I found this on our beloved discussion board, TT Clutch Issue but I'd like to confirm exactly what the problem is before I start in on any major work.
Thanks in advance for any help you can provide.
The slave cylinder on the 4 cylinder models requires transmission removal to replace.
To my way of thinking that would mean either the slave cylinder is out, or the fingers on the pressure plate or gone? Or maybe the throw out bearing? Your thoughts? I've had seriously bad luck with cars lately and would dread tearing this one apart. My job leaves me no more than about two hours in the early morning to work on ANYTHING, and I'm seriously strapped for cash regardless of what it would cost to fix this little gem.
For either issue, you need to remove the transmission to inspect & replace. The service manual will verify this in case I'm mistaken. I can't access mine at the moment as I have three cars down I need to work on. A service manual is mandatory if you're doing any repairs on these cars.
The clutch master cylinder is a very common fail point on these cars. However, when they do, they typically do in a spectacular fashion. The pedal will stick to the floor and brake fluid will get everywhere in the drivers foot well of the car. I would check the foot well, and remove the lower dash panel below the steering wheel and inspect the master cylinder and the areas around it looking for fluid. That could be the source of of a leak.
Mister Bally had one fail in his 1987 Audi 5000 CS Quattro, and it failed in the most spectacular way. It also ruined a very nice pair of shoes, but back to the important topic...
If you can feel the the line tensing up at all, you have some amount of pressure in the line. Check your brake fluid reservoir and make sure you have a level within the marked tolerance.
No matter what, if it is low or within, I would suggest bleeding the clutch line via the bleeder block for the throw out bearing. The Bentley manual for these cars says to use a pressure bleeder with a pressure of about 25psi. Make sure it is close to 25psi. Most hand pump pressure bleeders dont reach more than 15psi. I found this out the hard way after repalcing my clutch and had to rig up an air compressor with a tank to successfully bleed my master cylinder and throw out bearing.
Do this once, passing about 100 ml of fluid through the system. Then pump the clutch pedal 15 times. Pass another 100 ml through it, and again pump 15 more times. That should successfully bleed the entire system assuming you don't have a leak in the system.
If this doesn't fix it, I hate to say it but you will have to pull the trans and inspect it all. At that point I would have to believe the pressure plate has snapped all of its teeth off which make contact with the throw out bearing. Although I highly doubt it would come to this.
