2001 TT - alarm NiMh battery dead, where is it?
Symptom: randomly (about 5 times a year at night, usually under damp condition), the alarm goes off with the car horn and emergency flashers going off. This will drain the main 12v battery if not resolved. I thought that I just needed to disconnect the alarm 'puck' located behind the driver side rear tail light. This was based on the UK forum where left/right are of course opposite. However, I removed both tail lights, no alarm 'puck' to be found. the folks on the UK forum thought it might be on the passenger side in the engine compartment, but that's not very helpful.
Any ideas?
I've had a bad CCM and replaced it and his symptoms have nothing to do with the CCM. The alarm still works with a faulty CCM. The windows won't go up, but you can arm the car with the key.
And actually, the TT Roaster CCM is simple to remove with a trick. Remove the bolts that hold the rear of the top against the rubber seal in the back, with that done, you can ease the rear out and have complete unrestricted access to the CCM.But if you're going to fix the CCM, you might as well not waste your time until you replace the top. The leaky top was the cause of the CCM failure.
