Rattling sound when AC clutch is engaged
Old Jun 13, 2016 | 11:43 AM
marcogyver's Avatar
Default Rattling sound when AC clutch is engaged
As title mentions, everything else running fine other than the noise. I am guessing the ac clutch is going bad and not much else which can be done. I doesn't sound like a whining bearing but wondering if anyone had suggestions or input.
Thanks
Old Jun 16, 2016 | 10:53 AM
Rusty Spokes's Avatar
Take the serpentine belt off and see if the noises go away. If there is still a noise with the serp belt off..then it is something else. Check the clutch on the compressor with the belt off and see if it is loose or the bearing is notchey.
Another test is to turn the A/C off..and see if the noises go away.
If it goes away with the A/C turned off..could be the compressor (or the clutch)..if the noises remain with the A/C off it may be a compressor clutch rattling around.
Old Jun 19, 2016 | 04:26 PM
marcogyver's Avatar
It completely goes away when I turn AC off and sounds normal. I checked the center bolt which is tight, didn't remove belt to see it there is play but even if there is play what can be done? I don't see any kits for servicing the compressor.
Old Jun 20, 2016 | 06:57 AM
bstone's Avatar
I agree with Rusty- given that the noise goes away with the AC off, and it is a "rattling" noise and not a squeal- like a bad bearing- I'm going to lean toward the compressor itself rather than a clutch. Either low freon or just flat out going bad. Does it produce cold air when it is on? As Rusty said, I would still pull the belt and spin the clutch by hand. It should turn freely without any catching or dragging. If there is any resistance, the bearing is probably going out.
Old Jun 22, 2016 | 12:34 PM
marcogyver's Avatar
Fortunately it blows cold even on hot days, will pull the belt and check it out. Thanks.
stephenxchen
Feb 26, 2018 03:35 PM
kingsalami
Q5/SQ5 MKI (8R) Discussion
Jun 5, 2016 10:49 AM
colorado coupe
Jun 4, 2016 06:05 PM
kingsalami
3.2 24v VR6
Jun 3, 2016 07:18 AM
Tony Polizzi
A4 (B7 Platform) Discussion
May 23, 2016 05:09 PM
