Quattro not working (fwd not working)
So I have
1. Noise in rear end under take off
2. No fwd
I understand how the quattro system works. I don't understand how the Trans is not grabbing for the front wheels.
I swapped motors a while back. I changed the Trans fluids well.
When the car is put into gear and the clutch is let out you can hear that the front is not engaging!
The Trans was in perfect working order when the motor went out. I swapped the motor with another audio to motor.
Still have a rear end noise tho. I have changed the brakes front to back top to bottom. With the tires in the air the noise is not there. If the car is on the ground i have a bad noise as i take off. I put some pressure on the e brake and took off and the noise sounded about the same (which is why i bought all new brakes). I can tell now that the noise is in the center section (diff). I swapped out the motors. I had the rear shaft off for months. COuld the shaft just not be tight to the trans and letting it grab or something?
Anyway. Ill look at the front end tonight. What about my rear end noise tho. Its just just i let the clutch out and in the rear.
The front is not working right now so could that be why i have rear noise? The system is overloaded! maybe
To replace; Transmission has to be removed. Might be easier to remove engine & Trans as a unit.
See here for some pics: Not easy to diagnose remotely. I don't think the timing belt can be thrown by one tooth. There are too many teeth that would have be thrown on either toothed wheel.
You can remove the upper and lower timing belt covers. Then you can move the crankshat to the TDC position and see whether the camshaft toothed wheel "dot" aligns with the mark on the valve cover. Service manual required or good luck with a free youtube video which I wouldn't trust.
I'm going with either a cracked piston skirt or a snapped connecting rod bolt. You have some time before disaster strikes with those. But fair warning, these things won't heal themselves.
Check our what a snapped connecting rod bolt can cause:
https://www.audiworld.com/forums/tt-...story-2901563/
My main concern is the rear end noise. Why do i have it now and not before the motor swap? It sounds like the brakes dragging but with the rear in the air i get no noise when i let the clutch out. Its only with the cars weight do i get the noise. It could be a binding bushing noise or something like that. I bounced on the car and could hear no noise. Its only when letting the clutch out and power goes to the rear that the noise happens.
