2001 Audi TT Problems: Transmission, radiator fan, everything now
Car running, driving, sounding perfect. Has miltek exhaust, diverter valve, no cat. AC no work
I read end someone going 10mph
, breaks bumper, ac condenser, bumper core, front mount, and dents fender. I fix these problems. (ehh)
Radiator doesn't quiet go back how it should, on secureness, keep in mind.
When car sits at idle for longer then 5 minutes the (smaller) fan on the left spins continuously, makes loud noise and won't stop on it own.
I drive it anyway and just don't let it sit and idle as it will not do this while driving.
Few days later- Driving on highway when I notice a faint grinding noise when I step on the gas pedal with moderate pressure. Gets worse very quick. Now loud grinding noise. Quickly turn around and go home. Haven't drove it in a few days. What is this problem?
Details on problem above^^^: ONLY when in gear. ONLY when giving it gas. IMMEDIATELY goes away when you get off the gas. Happens in EVERY gear. It stays in gear but doesn't seem to give the car as much power as previously. Sounds like it coming from transmission. While out of gear it makes zero abnormal noises when giving it gas. The noise does not change when pressing in clutch and there is nothing abnormal about how the clutch normally operates, smooth and nice. HELP ME
It is likely you have multiple problems causing this.
No outside shop will attempt repairs leaving things "not secured". every piece of the vehicle that is cracked or bent needs to be corrected.
I personally do not keep collision insurance on vehicles over 5-7 years old. That said, many Audi's that are involved in "minor" front-end collisions are considered totaled.
Don't be alarmed if you are mechanically inclined and have time & money. Everything can be repaired. A spare car is essential for typical older Audi owners though.
Volvo V70R's driveshaft would get rubbed on by the exhaust in certain situations. I had one car the shaft was sooo grooved the PO must been deaf.
PS: Put the CAT back on. Stinky polluting exhaust.
