Power top
Old Jan 24, 2017 | 11:26 AM
fpo1123's Avatar
Default Power top
I have replaced the pump and top switch on my 2002 audi tt. The top wont open with the switch, but it will come up with the switch. when I push the switch to open the top I get nothing, no noise no movement "nothing" Any suggestions?
Old Feb 3, 2017 | 08:16 AM
bailee's Avatar
Loose wire connection, bad switch or bad ground. Ohm out the switch. if it's good clean the contacts and re-fit the connectors. If that's not it trace the wires using your manual and check for continuity. Continuity will determine if a wire is broken or loose at a molex.
brpaulsen
Jun 28, 2018 05:56 PM
AudiQua
Nov 27, 2008 09:11 PM
audi 273
Nov 5, 2006 06:02 PM
Nachos
Aug 9, 2001 11:37 AM
BukkakeRocky
Oct 22, 2000 10:16 PM
