TT not starting no power supply to ECU?
New member here. My name is jamie from rotherham south yorkshire.
I have a 1999 V plate TT i baught cheap from a friend of mine as a non runner.
My problem is i seam to have no power supply to the ECU ir what i think!
I checked my fuel pump relay under the drivers dash pannel and other two relays under the bonnet on the right side (standing at the front of the car) of the bulk head all are working fine and contacts inside are very clean and if i click the fuel pump relay in it sends fuel direct to the fuel rail BUT on ignition not one of the relays are clicking to make up the circuit in order to start. Also no fuel is delivered to the fuel rail. Theres power to the relays and power to the injectors and power to the coil pack but still dosent start when i crank the car over. Also there is no engine management light lighting up on the dashboard when the ignition is turned on giving me the idea the ECU is not powering up? Just to note inhave checked all fuses on the drivers side fuse box and all are ok. Does anyone have any ideas what i could try next or have i missed anything that may need testing or checking? Next option is to have a look at the ECU and is their another relay in with the ECU inside the protective plastic box under the windscreen?
Thank you all in advance for any help
I'm seriously about to scrap mine. 4 weeks its been off the road. Just wouldn't start one morning.
How do we find out if its in crash mode (immobilized)
Regards
Darren
I was thinking its a bad ECU, but haven't been able to narrow it down..
-john
Basically I was going to jump the main power to the ecu straight from the battery so to do do had to strip some of the black tape from the ecu connectors, looking straight at it from the front of car its the connector on the left.
I started stripping this back, maybe 8 inches to find the correct live wire and there it was, a corroded broken wire. It seems Audi used a plastic connector to allow 2 wires to become one wire and over time the plastic decayed, like an old rubber elastic band.
Reconnected, soldered, wrapped back up, Vedder started and ran prefect.
I reckon every tt of a certain age will develop this fault at some point.
