2000 TT w/52K miles had a strange start
Car had been sitting for 2 weeks or so but not uncommon for me.
Got in this afternoon to fire it up, turned over fine but sounded as if I had no compression. Usually it fires right away even after sitting. I cranked for about 10 seconds and again it sounded like no compression or as if the timing belt had jumped.
Another 10 seconds of cranking the engine and if fired but ran poorly like 2-3 cylinders or something. I let it run at low RPM's for about 30 seconds and it finally cleared up and began to run fine.
I turned off the engine and turned it back on again to see if it repeated but it did not. I have driven it several more times and she always starts and runs great just like she has for the past few years.
I have never experienced this before with this car and it did not throw any codes or lights on the dash.
Wondering if maybe the hydraulic lifters had bled down from sitting and thus the reason it sounded like it had no compression. OR, did the engine timing belt jump during initial start up and then jumped back to the correct teeth. As I said, the car has 52,000 miles but the belt has never been replaced during the last 17 years. OR, maybe it is something else going on?
Any advise would be greatly appreciated and thanks in advance.
Mike
Great fun troubleshooting a defective fuel pump or wiring issue to the fuel pump.
Just seemed like it jumped a tooth on the timing belt or a few seconds or lifters were not pumped up or valves were sticking open. Just not familiar enough with the engines to figure out what it could have been.
Just got a quote today for $900 for a new timing belt and water pump, seemed like a fair price. As I said before, I believe that this is the original timing belt.
