1991 Audi 100 VSS
Old Apr 24, 2017 | 09:22 AM
jbofcg's Avatar
Default 1991 Audi 100 VSS
Been around the block with replacing the Vehicle Speed Sensor on my 1991 Audi 100 4-speed automatic. The sensor I found in the car was the one sold for manual trans., not automatic (L-shaped-long probe). Ordered the "perfect fit" sensor for automatic, and it is an "ABS VSS SC198", but doesn't fit.
Can I just order the manual trans. sensor and install?
Old Apr 24, 2017 | 01:36 PM
Rusty Spokes's Avatar
Sounds like you got an ABS sensor for the brakes..you need a part number 095927321C
Costs about $14 from Hans, see the link:https://www.hansautoparts.com/095927...eedSensor.aspx
Old Apr 24, 2017 | 04:12 PM
jbofcg's Avatar
Thanks Rusty Spokes. The part you recommend is correct, and it's identical to the one I ordered. It's possible I am looking at the wrong sensor. The one I'm looking at is just inboard of the flange at the transmission output, driver's side. You don't have a picture of the VSS location, just to confirm?
Old Apr 24, 2017 | 05:52 PM
I think the sensor you are looking at is a multi-function switch, located there as you described.. part number 095919823C if it looks like this:
NLA from VW/Audi..it was used on early Eurovans and other VWs..and can be had from Germany or maybe here in the USA from Ebay. https://en.partacus.de/spareparts/de...f3fc7dc1381a8/
Old Apr 24, 2017 | 06:12 PM
Is this where you are seeing the part?
Old Apr 25, 2017 | 09:43 AM
jbofcg's Avatar
Yes, that's it. Black connector behind flange, with wire coming down from top.
Old Apr 26, 2017 | 11:17 AM
jbofcg's Avatar
Rusty-thanks for the picture! Which of the sensors pictured would say the VSS is?
Thanks, jbofcg?
Old Apr 26, 2017 | 02:56 PM
Thanks, jbofcg?
That black plug with the sensor is a mystery..I will check..could be a VSS. I don't know exactly..caught the picture on the web.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 26, 2017 | 03:09 PM
Looks like you need a 095927321C VSS sensor..
Could be a 095927321A...but most suppliers list that for VW.
You should have a part number on the sensor to confirm..I would go with the "C"
Old Apr 26, 2017 | 06:02 PM
jbofcg's Avatar
Thanks Rusty! You've been a big help.
