Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
Can the RS3 dash display be set to not auto extend on startup?
Old Aug 4, 2017 | 06:04 AM
motopix's Avatar
Default Can the RS3 dash display be set to not auto extend on startup?
I did some searching and have not found the answer:
Old Aug 4, 2017 | 06:13 AM
vassili_z's Avatar
i've gone through the settings menu a couple of times. didn't see anything. i've just gotten used to pushing the retract button. it's pretty easy to reach. plus i like that the screen is up most of the time so i can scroll through my music.
Old Aug 4, 2017 | 06:39 AM
mf44's Avatar
You might be able to find something through VCDS to prevent it from rising at start up. The issue I could see, though, is that most people will be reversing out of a driveway or parking space shortly after startup, so the screen will lift to show you the reversing camera regardless.
Old Aug 4, 2017 | 06:49 AM
motopix's Avatar
Ah good point about the reverse camera.
Old Aug 4, 2017 | 08:40 AM
mattvandyk's Avatar
If you have MMI off, it should not extend on startup until you put it in reverse at which point it should pop up for the backup camera, and then retract again automatically once you get over 12 MPH. I forget which video it was, but there's a video of a guy who has this setup.
pninja005
Aug 6, 2018 01:18 AM
tounphic
A6 (C7 Platform) Discussion
Dec 2, 2016 12:58 PM
***Cadmium***
Q7 MK 1 Discussion
Oct 1, 2007 12:50 AM
Imola Ghost
Jan 14, 2004 06:52 AM
Jamie '87 CGT
Nov 7, 2001 11:56 AM
