RS3 Homelink?
https://duckduckgo.com/?q=Chamberlai...1Kv1TlF9LL.jpg
The latest I have found is that if you have the upgraded camera in the higher line trims of Audi Pre-sense (Prestige S3 and RS3) there is no room in the headliner for the Homelink transceiver. The lower trim variants of the 8V have it (Premium Plus S3). I learned this the hard way as I test drove a PP which had it and assumed my Prestige trim would to as well. My car does not have it and the dealer did not help in getting it installed for me (port installed only).
I would imagine it is on your RS3 order sheet that needs to be checked.
Just like with "Resonator Delete Sound Enhance" option. It is not listed anywhere with Audi on their site but when you order a car it is on the custom order build sheet as a port installed option.
My guess is Homelink would be on this sheet that you need to tick the box (~$359MSRP). If not, then they have not fixed the clearance issue.
I did read a thread here of someone who retrofitted the transceiver. I think it mentioned having the connector in the wiring harness and only the switch pack needing to be plugged in for operation.
I was able to program a Liftmaster and 2 Genie doors with it fine.
Once it is programmed correctly, you can get it to open the garage door with a simple short click of the button on WHY EVO. You don't need to hold down the button like on homelink.
https://www.youtube.com/watch?v=1SMY4izO204
