Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
RS3 Exhaust Valve Mod
Old Aug 20, 2017 | 03:50 PM
dbturbo2's Avatar
Default RS3 Exhaust Valve Mod
On my last gen TTRS you could disable the exhaust valve flapper in the open position by crimping the rubber host leading to the actuator on the left exhaust with a ziptie.
Anyone know how to do the same on the 2017/18 RS3?
Old Aug 20, 2017 | 04:05 PM
markN1689's Avatar
disable them in vagcom. i like the flaps- they help add to the cool fart noise
Old Aug 20, 2017 | 05:21 PM
dbturbo2's Avatar
Thanks, is there also a mechanical way to disable them?
Old Aug 24, 2017 | 06:22 PM
Alt3rEgo's Avatar
I tried VCDS tonight and it says there is no long coding for it.
Old Aug 25, 2017 | 04:29 AM
Audifourme's Avatar
I believe that on the new RS3 and TTRS they are electrically actuated, not by vacuum. Once I get mine in about a month or so, I'll look at finding the signal on the actuator and see if the is a way of installing a manual switch in the cabin to just send the signal to the actuator so it can be controlled manually like on the new TTRS.
Old Aug 25, 2017 | 04:59 AM
CoOlSlY's Avatar
I read somewhere just by unplugging the two connectors were doing the trick but haven't tried it, maybe somebody can confirm
Old Aug 25, 2017 | 04:57 PM
Micronaught's Avatar
Yes, unplugging works fine. But a switch would be ideal, I like being a little more discrete sometimes leaving the house at 5am. The oem ttrs button would be great in the stop/start switch location .
Old Aug 25, 2017 | 07:00 PM
And yes that wireless AWE unit might be ok, but it still results in our current issue ..i.e.
The default valve position is “closed”. Upon turning the ignition off, the valve will eventually return to the “closed” position.
 Pouria Savadkouei
 Michael S. Palmer
