Rear window heater, lights and central lock problem at same time
And my central lock has sometimes been slow (need to bang on the defa remote for it to work). And last time i locked my car the defa remote would not work.. Have no idea if it is the remote or the car. So now my car is in alarm mode and can't turn it off.. Had to cut the wire to the horn to not scare the neighbours every time i use the car.. So i can use the car but the lights blink for 2-3 minues before it stops. Tried taking fuse 6 and 38 out to disable it.. Don't do nothing.. But i would like to fix the problem also.
Anybody got any ideas for the short and longtern fix?
My car is a 1999mod 1.9tdi
Old wires, shorts, ground issues......
Mike
And is the reciver box located under the steeringwheel where all the relays is?
The control unit for central locking/alarm is in the footwell below the carpet in front of the left side front seat (driver seat on LHD cars.)
Since you mentioned in your first post that the rear defrost was occasionally not working, that may be related. Check your wiring.
I got a feeling too that it can be the keyfob that is the problem.. Can i just get a new non original for to work on it?
But still wonder why my rear window always freeze up inside. Is there some moisture leaks that are known from that area?
Yeah i'm thinking the fob is bad.
