Timing Belt- Major Question!!!!!
1999 A6 Quattro, about 210,000 miles, Timing belt was replace at around 158,000
About two years ago I was driving back to my place of employment in the mountains, heard a awful noise coming from the front, opened the hood and something flew right past my face- a blade off the fan clutch. I thought, I better slowly get this back up to my shop, but about 100 yards further the car died. Opened the hood and saw the whole fan clutch bracket was off the front of the engine toward the bottom and the belt was just destroyed, strings all wrapped around mostly the crank pulley.
Jumping ahead….I have been so busy that I haven’t been able to work on the A6, until this week, when I was invited to have a change in employment. The car has been up on blocks since then, been meaning to get to it. Since I needed to fix the fan assembly and it was getting near time for a new timing belt, I decided to do that while I had a good garage. Four days ago, I put the car in service position, looked at the fan bracket- to me it looks like with the fan was out of balance and it vibrated the bolts completely loose…they are still in the mount with no apparent damage. The accessory belt has pieces stuck behind the crank pulley.
I have the cam bar and the crank pin. The crank however would only move about 2 inches as I tried to get it to TDC. I pulled the plugs to relieve possible compression, and made sure it was in neutral - still wouldn’t hardly budge. I had an experienced foreign repair shop owner from the near town come up and look. His suggestion was to burp the crank by hitting the starter briefly until the the crank was at TDC…worked. However, we noticed the cam oval pieces with the two holes were straight up, not sideways like they were supposed to be, indicating major slippage.
We pulled the valve covers to check on any damage and could see none. Watched pistons move and ascertained that when at TDC the #3 piston was at the top (still assuming that is the first piston to fire). There is no evidence of any damage to the timing belt…no missing teeth, rubber, etc.
The question I have and 3 different mechanics I have conversed with have is how could the original problem with the fan clutch have caused this apparent misalignment of the valves. Is it possible this particular engine has a different arrangement for the holes on the cams? If the only connection to the actual timing system is the crank pulley, could the breaking belt have caused that massive of a jump? Am I looking at major damage or this just some weird aberration. One mechanic said I might be able to just remove the old timing belt and hand turn the cam wheels into the correct position based on his experience …
Like I said, it’s not just me that’s stumped ….3 mechanics including a very well seasoned one.
Input anyone?
Unfortunately I think you now have a parts car.
