Open Hose Question
Old Feb 10, 2018 | 03:40 PM
Graverobber's Avatar
Default Open Hose Question
Hi y'all,
I have a 1996 A6 Avant with the 2.8 and have an issue with a hose that I can't seem to find a place for. The hose is rubber - black with a green stripe and about ⅜ OD - and runs from a T along the driver's side cam cover to behind the engine where it terminates in a right-angle connector. The other hoses on the T both seem to go under the ABS pump behind the PS reservoir. I've checked and it's not pulling vacuum.
Does anyone know what this hose might be and what it might be supposed to connect to?
Thanks in advance.
Old Feb 10, 2018 | 04:47 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Wrong forum. Your car is a C4.
Old Feb 10, 2018 | 09:27 PM
Wait, isn't this...? Oh for heaven's sake, I overshot. Thanks!
Old Feb 10, 2018 | 09:29 PM
Sorry, my car is a 1999, not a '96. Long day.
Old Feb 11, 2018 | 03:18 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Sounds like cruise control, which is vacuum controlled in the 1999. It does not, however, run off engine vacuum, but off its own pump that only activates with cruise. One hose goes to the pump, one to switch on the brake pedal (inside the car) and one to the vacuum servo at the throttle body.
Old Feb 11, 2018 | 09:27 AM
That makes a lot of sense. I think this may be the brake switch hose. I'll see if I can trace the connections back from there and the TB. Thank you so much!
A62.7TBend
May 28, 2012 05:06 PM
I'm No Pro
Feb 7, 2007 01:26 PM
sbratton
Mar 20, 2006 05:51 PM
azn123
Jun 27, 2005 05:07 AM
cbpldc
Apr 3, 2002 02:27 AM
