steering clunk not rack
Old Mar 1, 2018 | 07:51 AM
clancy's Avatar
Default steering clunk not rack
2001 A6 2.7 with what sounds to be a clunk possibly coming from driver side front suspension when going over bumps over 10mph. Replaced 4 lower control arms and top strut mounts. Other components inspected and were fine as were tie rod ends. This was done by an indi shop I trust. The clunk was improved but not eliminated. I checked the two steering rack bolts on top and they were tight. Actually used a torque wrench set at 50# and it clicked. Did not bother with the one on the bottom that is reportedly very difficult to access. Assumed (I know) if the top ones were tight then this one should be as well.
What next?
Old Mar 1, 2018 | 08:24 AM
georgeb944's Avatar
You may have a noisy shock absorber.
Old Mar 1, 2018 | 08:28 AM
clancy's Avatar
Noisy? I understand worn and soft but not noisy. They are Bilsteins with 100k on them, but ride is still tight or stiff, not bouncy.
Old Mar 1, 2018 | 01:48 PM
johnkk's Avatar
Did he check the sway bar links and bracket bushings? Motor mounts and front snub mount bushing? Only other things I can think of.
Old Mar 1, 2018 | 02:47 PM
clancy's Avatar
Many of these have been replaced. But maybe ready to be done again. I will check. Thanks
Old Mar 2, 2018 | 08:36 AM
Boston Driver's Avatar
AudiWorld Expert
For me it was the bushings for the front sway brackets. Dried out and hard as a rock, no longer gripping the sway bar and resulting in clunks.
Old Mar 3, 2018 | 09:18 AM
clancy's Avatar
Checked the sway bar bushings, links, snub mount, and motor mounts. All looked good, not cracked or torn or otherwise looking suspect. Back to the shop for a professional to inspect.
Old Mar 3, 2018 | 10:24 AM
johnkk's Avatar
Maybe you did this, but to check you really need to pry the joints (including ball joints) with a giant screwdriver or a pry bar. Also have a helper turn the steering wheel and watch for any slack. Snug up all the nuts, ball joints especially. Check the nuts on the top of the shock mounts under the hood. It is easy to forget to tighten all the nuts, when you are tired at the end of the job...even a pro.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 4, 2018 | 07:21 AM
clancy's Avatar
Yes, you are correct. I did a cursory look. Should have been more thorough. Admittedly I did not want to find anything wrong. Not sure I want to replace parts that are not clearly in need of replacement. I accept this car is old and expect some unwanted noises. Just not parts that might fail and cause an accident. I will report back after my shop people have another look.
Old Mar 5, 2018 | 03:47 AM
blink's Avatar
Default Just a guess....
On my A6 I chased down every last clunk, squeak, and wobble. Check the play in the steering rack. My last clunk came from there. I jacked up the car just a bit to relieve most of the weight from the steering, and turned the wheel back and forth. At a certain height I could reproduce the clunk. After that, I MILDLY adjusted the nut on the rack to tighten up the steering play, and no more clunk.
greenaudiurs4
Audi Original "S" Cars
Oct 19, 2007 06:29 AM
S4orceaudi
Feb 28, 2007 06:05 PM
victor army
Apr 3, 2006 11:02 AM
markbradford
Feb 3, 2004 09:59 AM
crisco
Feb 14, 2003 11:04 PM
