Brake pedal goes to the floor. Why?
Old Mar 31, 2018 | 10:21 AM
rxpclb's Avatar
Default Brake pedal goes to the floor. Why?
Today as I pulled into my in-laws driveway I noticed the brake pedal went all the way to the floor. It slowed down initially, but when I went to apply more pressure to the brake pedal to stop the vehicle, it simply went on through to the bottom.
In the past 9 months I’ve had the brake fluid changed. My 1999 A6 quattro has over 266,000 miles on the odometer.
Any idea what’s going on with my brakes?
Old Mar 31, 2018 | 10:38 AM
georgeb944's Avatar
How's your brake fluid level? If it's going down, look for a leak in one of the lines. If not, you may have a bad master cylinder.
Old Mar 31, 2018 | 11:27 AM
Dr.Aronis's Avatar
There is a test for that via VAGCOM, involves pumping up the break and then testing the pressure held via VAGCOM. Check Rosstech for details.
ESP System Function Test - Ross-Tech Wiki
Mike
Old Mar 31, 2018 | 01:50 PM
rxpclb's Avatar
Default Now the Brake light is flashing!
Now this wonderful brske light has come on in the dash and it flashes and makes a singing noise to boot!
Old Mar 31, 2018 | 03:40 PM
Harleyguy's Avatar
What george said. If fluid level is ok then hook up VAG Com for error diagnosis.
Old Mar 31, 2018 | 05:15 PM
rxpclb's Avatar
Default Leak in Right Front Wheel Found!
I stopped by my local O’riely Autoparts store and the tech had me start the car and pump the brake pedal. I then backed up and sure enough, there was a puddle of fresh fluid on the concrete and there was brake fluid on the rim (see pics).
Now ny question is on how to replace the brake Lin to that right front tire. Should I replace the other lines at the same time?
Old Apr 1, 2018 | 12:49 AM
georgeb944's Avatar
Before you start buying parts to replace, you should do a bit more diagnosis. Jack up the front of the car, use jackstands, remove the wheel, add fluid and have a helper press on the brake pedal while you observe the source of the leak. It might be a hard line, or a rubber hose , or a connection. Depending on what you find, you should check the other lines for similar problems. Resolve those as necessary.
A good shop should.be able to do the job right.
Old Apr 1, 2018 | 09:48 AM
rxpclb's Avatar
Thanks for the suggestions. I’ve had good luck at my local VW dealearship. I’ll see if they can look at it Monday.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 3, 2018 | 04:53 AM
johnkk's Avatar
Replace flex brake lines on both front wheels at this age. Make sure caliper is not leaking, but I'll bet it's the lines. Did mine this year. Easy if you spray Pblaster on fittings before unscrewing. Use special tool (golf tee) to plug hard line so you won't loose much brake fluid. You will have to bleed each caliper. I have a hunch that you will have a shop do it, though.
oliwer78
Audi Original "S" Cars
11
May 30, 2008 05:08 AM
ihaveanaudilikeyou
Jan 24, 2008 11:21 PM
Mike Desi
Quattro: Turbo / Ur / Sport
Jun 14, 2004 02:58 AM
Niksa
Audi 100 / A6 (C4 Platform)
Aug 14, 2003 04:29 PM
Elberoth
Performance and Tuning
Jun 14, 2003 02:31 PM
