No start
My concern is that my fuel gauge was showing about 1/8 of a tank and I can drain the tank to E with no problems in the past. BTW, Car is on perfectly flat level ground. I've never had any problems with the fuel gauge and I am able to surf every vapor of fuel out of this thing till it is on or below E. She's showing 1/8 tank.... WTH? I HIGHLY suspect it is a low fuel issue & fuel gauge is off, however, I would like some direction to rule out other things such as fuel pump, CTS, Speed sensor, and such?
Thank You for the help!
Just looking for some direction to figure out what the problem is and is not. Thanks
Well, I put in 2 1/2 gallons of 87. I have an APR stage 1 tune and I had selected it back to the stock position, reset with no results. I had started the car and it would idle for about 10 seconds, sputter and die every time. Finally it started yesterday after multiple attempts and after I had added the fuel, fuel gauge is now reading above 1/4 tank. I was showing no codes and as far as I was concerned, it was most likely a fuel problem, low fuel.
Well, this morning, I go to start my car fully expecting it to start up and it sputtered and died multiple times...again
. I pulled off the gas cap just incase it was some sort of funky air in the tank and the car tried to start. When the car was running at idle and i stepped on the throttle, the car would die. Then it would sputter from idle to 1200 once I got it started. Then If I pushed on the throttle the revs would jump up normally. I then drove it down the street and it drives like nothing is wrong??? WTH???Now, for the interesting comment Clancy stated. two months ago, I spun out in some snow and landed in a small ditch. I had to get a tow truck as I was stuck in a little dip off the shoulder. I wonder if something like the pick up tube got displaced. I"m a little confused as of what line your talking about as I"m not as familiar with Audi's as I am Chevy's
I"m sure that I can figure it out, just need a little direction
Also, I do know that when you turn the key on, you can hear the fuel pump prime on Chevys. does this occur with Audi's?
I've no idea. Seems like when it's COLD and has sat all night, it starts for a few seconds and dies. Each time I start the car, it runs for a few seconds, sputters and ides. Then, once I touch the throttle, the car immediately dies. Seems like after multiple starts, once the car starts to get luke warm, it holds idle for a minute, I punch the throttle and it sputters up to 1200, then rev's past the sputtering mark, 1200rpm's, and it revs as high as I wish. Once it warms up, the car drives as if nothing is wrong?
I just cleaned the MAF, checked connections, oil, water, everything looks fine. Guess I have to wait till tomorrow to see if she does it again or not.....I hate these types of gremlins
I have been searching for hours. I put vacuum to the fpr and it holds vacuum. I put the vacuum pump to the hose that feeds to the fpr and there is no vacuum, I think this is normal for this hose?
I looked into putting a gauge to the fuel line, but there is no schrader valve to hook my fuel pressure gauge to the line.
I disconnected my ECU and cleaned the terminals.
Checked fuel pump fuse which was good.
So, how does one check the fuel pressure on our cars? My torque pro does not have a way of reading the fuel pressure that I am aware of.
And what is the best way to check the fuel pump? Not sure it's the pump as it only acts up when it's cold or has sat for over 4 hours. Once the car is warm, runs fine. No codes either
I also hooked up vag com light and showed no codes.
I also hooked up vag com light and showed no codes.Trending Topics
A few thoughts, bad fuel? I put 87 in because it was the only fuel offered at the station and I was almost on E. I put 5 gallons in. I considered putting a 5 gallon of 92 with some fuel stabilizer, but I don't want to have to pull the tank with 5 extra gallons in it if it is the fuel pump. That being said, How do I check the fuel pump? & how do you test the fuel pump relay?
I tried to connect via VCDS. I have the light version and it would not allow me to read the fuel pressure
I Put a vacuum gauge to the fuel pressure regulator and the car had no change to it upon start up. I put zero and 20mm/hg vacuum to the regulator with no change either way. Car just sputtered and died.
Now, how to test the fuel pump?
Thank you guys for the help.!!!
