2001 Audi A6 not starting
Old Apr 25, 2018 | 06:48 PM
Pgracia1's Avatar
Default 2001 Audi A6 not starting
I just replaced the ICM's on my 2001 Audi A6 Quattro 2.7 Twinn Turbo. The car started right away and ran great for 3 days and now it won't start. Do I need to reflash my computer after replacing the ICM?
Old Apr 26, 2018 | 11:37 AM
raj99's Avatar
Tech Guru
Tech Guru
Your vehicle is a C5, try Searching here: https://www.audiworld.com/forums/a6-...-discussion-7/
If it ran great and "magically" stopped running, it's not you needing to reflash, there's no such thing as a 3 day limiter on the ICM...you need to figure out what the issue is.
Old Apr 26, 2018 | 12:01 PM
georgeb944's Avatar
Check your crank position sensor.
Old Jun 8, 2018 | 09:57 AM
stealths6's Avatar
Where is this located and would this show up on vagcom scan?
Old Jun 8, 2018 | 10:37 AM
georgeb944's Avatar
It is located on the bell housing near the flywheel. Typically it does not show up on a vagcom scan.
Old Jun 9, 2018 | 06:29 AM
clancy's Avatar
Search old posts for CPS diagnostics. There are ways to tell if this is your issue.
Billy Pruter
New Member Welcome Area
May 12, 2019 09:36 AM
harryb5a4
Aug 16, 2011 03:59 AM
oillady
Mar 8, 2009 04:06 PM
problemsolver
Jun 30, 2008 04:49 PM
