Not sure how to address Error Code P0322
It was error code P0322, no signal on the ignition/distributor engine speed input electrical circuit for a predetermined period of time.
Probable causes: 1) Poor Electrical Connection 2) Faulty Knock sensor (Was told not likely to be the problem)
The problems started a couple months ago when my car would fail to start on rare occasions, but given 30 minutes or so it would start right up without a problem. However, as of a few days ago, the problem started to occur quite often leaving me stranded wherever I had parked. Now it is sitting in my driveway and I am not sure where to continue on from here. I can still start it without a problem more often than not, but often enough it will just fail to start, with the engine obviously trying to ignite to life but failing to do so entirely.
