Having trouble with Lucas floating calipers on an A6
Old May 25, 2018 | 07:03 PM
preoptopus's Avatar
Default Having trouble with Lucas floating calipers on an A6
2000 a6 2.7t
So i inherited this mess from another mechanic. Car comes in with no brake pedal and rotors grinding. Car has the Lucas floating 4 pad calipers in the front.
The guy put the wrong rotors on it cause they were grinding into the actual knuckle. and the calipers look like this
Notice how the caliper is grinding right where the pads are but the pads look new? I put the correct size rotors on it and still have the same problem. What am I missing?
tia
Old May 26, 2018 | 06:13 AM
clancy's Avatar
Are you certain the pads are free to contact the rotor? Can you slide the mechanism easily by hand? Does the piston move freely? Pump the brakes and verify.
Old May 26, 2018 | 07:50 AM
preoptopus's Avatar
Yes the caliper pads and rotor all all brand new.
Old May 26, 2018 | 08:42 AM
Harleyguy's Avatar
Clancy didn't ask if the parts were new. The pads look new but show signs that the caliper isn't moving freely once installed. The caliper mounts on two pins and must be able to slide in and out on those pins. It is common for brake dust and dirt to cake up on the pins and hinder their movement. All points of contact for the caliper should be clean and rust free. During reassembly a very light film of anti-seize lube on the sliding surfaces and pins is a good idea. You also need to make sure your rotors are the correct ones for the car as there are several variations available depending on what brakes are to be installed.
Old May 26, 2018 | 09:12 AM
clancy's Avatar
Go to this website and look at the HP2 caliper torn down. You will see the slide mechanism that needs to move in for your brakes to function properly. http://www.a4mods.com/pics/caliperrebuild/IMG_1889.JPG
Giantcod
Sep 4, 2011 07:05 PM
2.7tDallas
9
Mar 18, 2009 09:21 AM
oskidunker
10
May 5, 2003 08:35 AM
DWP
14
Aug 28, 2002 09:48 AM
