Fuel Consumption constantly rising when stopped
The car is an S6 C5 from 2000 ANK, with 230000 km on the ODO, LPG, with replaced one pre-cat O2, and replaced vacuum lines, cleaned TB, 8 new spark plugs and 2 new ignition coils... NO CODES whatsoever.
Short term fuel trim on the Bank 1 is a bit off, but acceptable as there is no code.
Cats are emptied, post cat foulers installed.
Car runs like a train, but consumption is still somewhat on the high side.
Now the biggest/strangest problem: When stationary and engine running, at a light for example:
1. The instant consumptions never shows the same numbers. (like consumption per hour). it randomly stops at a number...
2. The average consumption keeps climbing... depending how long you stand still, it will go as much as few liters...that can't be right...
Thoughts, ideas,experiences
Very grateful to all!
In the US, where our dash displays distance/volume rather than volume/distance, I think the instantaneous display also freezes on every Audi model I've driven. The ratio fuel/zero distance is ill-defined and Audi decided to halt the display rather than be cheeky and display an infinity symbol. When you engine-brake or coast down steep hills you can also see the instantaneous display change to "---" once the opposite happens, and you are covering so much distance with so little fuel consumption that they do not have the display digits necessary to show the ratio.
Since the average display is computing a ratio of two sums which are both non-zero, it can keep updating as the fuel sum increases and the distance sum stays fixed. If you reset the average display while stationary, it also will be frozen and won't display a value until you drive far enough for it to start showing a plausible value again.
I forgot to mention I am new to the C5 scene...I also have a C6 2.7 TDI , and it's a different story there. Previously been a VW driver forever and just assumed Audi is the same.
In any case this feels good, as I don't have to chase a problem.
Took it for a spin on the highway over the WE, and it dropped down few liters, starting to look normal.
But from what you all are saying I shouldn't count on the accuracy of the average consumption meter. I will try to measure from tank full to tank full.
