new FCM & still overheating
I don't understand. In Denver at 95+ degrees outside all was fine. But after hitting cooler (82 degrees) the car temp went up??? Yes, I was climbing from 5280 to maybe 7000' or so, but it was cooler. Why did the car's temp begin to rise as I continued to climb to 8300 feet? When I got home I raised the hood with the engine running and the A/C on and both electric fans are running on what sounded like high. Faster than they ran for a couple of years. Turned off the A/C and the fans continued at the higher speed. Shut the car off and both fans stayed on but at a slower speed.
Is it safe to assume the temp switch on the lower radiator hose is working properly? I have never replace it. My understanding is if it is not functioning correctly then the fans or the FCM does not get the signal to go to a higher speed. Since my fans change speed going to and staying at a higher speed when the engine is hot that means this temp switch is working correctly. Is this right?
The car has 210,000 miles and has always had the correct Audi coolant. I checked between the two radiators (A/C and engine), it is clean, no build up of dirt or leaves or other obstructions. Do you think the problem is an old and clogged radiator? The belt driven fan appears to run fine. Could it be the viscous clutch? How do I test this?
What else? I am at a loss.Leaving soon on a trip to the East coast and do not want to have overheating issues on the road.
Any help will be sincerely appreciated.
When the car iis cold the viscous fan turns less than one third revolution if I try to give it a spin. It was about the same after driving to Denver and back. I understand if the fan clutch was worn out wouldn’t it spin freely? Especially when hot? Is this correct?
My logic says the radiator may be clogged. Is this expected for a car 18 years old and 212,000 miles? It has never had the wrong coolant. But I cannot vouch for always using distilled water. Just seems like if the fans are all working properly and it only rises above normal temperature on hot days with the AC on and under the load of a long elevation rise that the radiator is just not working as well as it should. But I don’t want to replace it if not necessary. What else might it be?
Not trying to shoot down your suggestions. Just wanting to be clear. I much appreciate any advice.
I remember my old 5KTQ had a rather marginal cooling system - with 2 bikes on the roof in the high desert of Nevada the temp gauge went into the red if I drove over 75 MPH, which would run the fans at level 3...which sounded roughly like a 747 at takeoff.
