Fan fuses
Old Jul 18, 2018 | 10:52 AM
Nicholas Mangiardi's Avatar
Default Fan fuses
Can someone explain where to look for the fuses for the high temp fan and transmission fan.
Old Jul 18, 2018 | 10:53 AM
I have an A6 2004 S model or C5.
Old Jul 18, 2018 | 12:22 PM
georgeb944's Avatar
[QUOTE=Nicholas Mangiardi;25181852]Can someone explain where to look for the fuses for the high temp fan and transmission fan.[/QUOTE
What do you mean by "transmission fan"?
Does "high temp fan" mean the electric fan between the engine and the radiator?
Which engine and transmission do you have? Do you have AC?
Old Jul 18, 2018 | 02:40 PM
I have a 2.7l T V6 with A/C yes it's the two electric fans the on the front and the the one on the engine radiator.
Old Jul 18, 2018 | 03:36 PM
georgeb944's Avatar
Actually, there is only one fuse for both fans. I have attached the wiring diagram for the fan control unit (fan motors and fuse circled) and the location of the fuse (circled). Good luck...
File Type: pdf
File Type: pdf
Old Jul 19, 2018 | 02:17 AM
Nmangiardi65@gmail.com's Avatar
Thanks George but now where should I look; under the plenum,under the ECM or under the steering column?
Old Jul 19, 2018 | 02:48 AM
georgeb944's Avatar
Under the steering column.
Old Jul 19, 2018 | 02:35 PM
Thanks again George.
 Pouria Savadkouei
 Michael S. Palmer
vtraudt
Audi allroad
15
Apr 15, 2015 03:39 AM
Avantugofast
Jul 16, 2008 11:01 PM
mktbully
Nov 8, 2006 04:27 AM
computrtutr
Jul 19, 2006 06:58 AM
crazyhomer
9
Sep 9, 2002 09:55 AM
