Audi Other 1987.5 Special Build Coupe GT - Second Owner
2.3 I5 engine (code NG)
5-speed manual
Digital dash (works perfectly)
Alpine white
177k miles
Two owner car
Cloth seats
No cracks or warping in the dash or plastic
THE GOOD: here is a partial list of parts I have put into it and work that I have done:
- fuel pump
- timing belt, water pump and idler pulley
- plugs, wires, cap and rotor
- complete radiator assembly including expansion tank
- heater core
- rebuilt and flow tested injectors
- CV shafts
- brakes (front and rear)
- wheel bearings (front and rear)
- O2 sensor
- knock sensor
- flushed and cleaned the gas tank
- rebuilt both window motors
THE BAD: remember it's a 30 year old car.
- Idle is a bit rough after it's warm, but it accelerates fine. I could never nail down the problem. I'm guessing it's a vacuum leak somewhere. The compression is good across all cylinders. I do have a spare fuel distributor and metering flap assembly that comes with it.
- The clearcoat is flaking in a spot on the driver's fender. A shopping cart hit it 20+ years ago, and the body shop painted it with a 2-stage paint instead of the original single stage paint. The rest of the paint is slightly oxidized.
- The driver's side seat heater does not work, but the passenger side does. It gets power to both, so I think it's a broken wire.
- The power mirrors don't work despite installing a new switch. The fuse is fine.
- AC needs to be converted to R-134a, so it currently does not have a belt to the AC compressor.
- Left rear emergency brake is seized, but the right still works.
PM me if interested.
