A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
2.0 tfsi - Low pressure fuel pump problem
Old Nov 3, 2018 | 12:22 PM
zielu's Avatar
Default 2.0 tfsi - Low pressure fuel pump problem
Audi a4 2.0 tfsi quattro - i have problem with to low fuel pressure on low pressure fuel pomp over 5000 rpm.
Logs - https://log.malonetuning.com/chart/241508#H8KLCABCwp3DnVsCA2XCjsORCsOCMAxFw78lw48pwqw qw6rCv8KUPlQbZmFrRsKawo3DjcKvd11BBB9zw649w5w4B0IjL 2Riw5BQSAEtwp49w77Do1PDg08eHynCk8OpwoXDp8KpAHYNDiz DqU3Du8KJw5BTJglKw5DCksK8wpDCqFE2wqsJa8KqRnNCwoxmw 7siwpDDlMK%2Fw7RQw7bCtcKfw4B1w7UhwrzDog3Drx7DgR7Cl TArwpdpSFobw7bDosO9B8KKw5JKwpDDhwAAAA%3D%3D
To check the pump I connected the pump directly to the battery and everything is ok. Over 5000 rpm pump give 5 bars.
I checked the voltage before the fuel pump controller and behind it under engine load.
Before - 13.8V
Behind - 5V to top 9V
I suppose it is not enough? I connected another pump controller and nothing has changed. I was unlucky and I came across a defective pump module or is it supposed to be like that?
(Sorry for my English. I hope that everything I wrote understandable)
hos79
17
Oct 4, 2020 10:02 AM
RingRat
A4 (B8 Platform) Discussion
May 13, 2018 08:14 AM
Saileon8
New Member Welcome Area
May 2, 2017 12:43 PM
clintmeyer
21
Oct 28, 2013 05:09 PM
The Librarian
Audi Original "S" Cars
20
Jul 6, 2004 04:10 PM
