Audi Other FS in FL: Built 1996 Audi URS6
For sale is my 1996 Audi UR S6 (originally from Canada). This car has been my daily driver for the past two years and has been enjoyable to say the least. For those who don't know, this vehicle has a 20V 5cyl 2.2l turbocharged engine that was used on Audi's racecars of the late 80s and 90s. She is equipped with a 5 speed manual transmission and upgraded clutch. She has racked up 200,000 miles but only 30,000 of those have been completed after her full mechanical makeover.
This car also has a wrap job as well as plastidipped front grill. The wrap on the roof has some wear and tear and the grill is showing some chrome. She also has some minor wear and tear on the seats that can be expected after 22 years. This car also is equipped with both front and rear heated seats as well as rear ac; however, the rear ac vent doesn't open so that is something that will needed to be looked at. Also the sunroof switch isn't installed but last time I used it, it worked (the sunroof seals well so no leaks). The scrape on the drivers side rear panel is from when a drunk driver couldn't pull out of his parking spot but the black paint underneath is fine.
This car has 1 year old tires on it, a brand new battery, new headliner, new driver seat bolster, recent alignment, and the oil was changed only 2000 miles ago so she has been well taken cared for. This car has gotten me to and from college at Clemson many times without difficulty and has even been driven for 26 hours in less than two days so it's safe to say that she'll get you to where you're going. I am selling her as I am moving to Denver and A. cannot take her with me and B. I need something larger. Below is a list of all the modifications that have been done to her, and in total it has cost over 20,000 dollars but every cent has been towards making her a vehicle that everyone from your kid next door to the grandparents can appreciate. The price is $9500obo. My phone number is 4089307084 (california area code is because I'm originally from there), text is preferable but calls are accepted. Let me know if you want more pictures. Located in Merritt Island FL
List of Modifications done by Wolfcars Motorsports in Doral Florida
Engine/Performance
Rebuilt Stock Turbo
Fully built head (5angle head job and upgraded with Supertech's complete valve train)
MaxxTuning Engine Management kit. (Fully optioned: Launch Control, Traction Control, Boost by gear, etc.)
MaxxTuning IAT sensor
034 RS2 injectors
034 Motorsports 3" downpipes
Full custom made 3" exhaust with Vibrant rear muffler (Sounds amazing)
034 Engine and Transmission Mounts
034 Adjustable cam pulley
034 Oil Catch can
Forge 007 Diverter valve
034 Intake manifold spacer
Maintenance done at time of upgrade
034 Timing belt kit with water pump and upgraded lower sprocket and head gasket kit.
New ignition coilpacks, spark plugs, mass air flow sensor and air filter.
New OEM A/C compressor, dryer, and switch.
New OEM driveshaft
New OEM starter
Interior
Custom made center console gauge pod
Stack AFR Gauge
Stack Boost Gauge
Wheels
Audi OEM 17" B5 S4 wheels
Suspension/Brakes/Mounts
2bennet Coilover kit with adjustable camber plates ($2000 set up)
034 Rear Sway Bar kit
2Bennet Front Big Brake kit (Porsche 911 (993) turbo brakes with red calipers
2Bennet Rear big brake kit (OEM A8 rear rotors and Pagid pads)
Carbotech xp10 fr Pad set (will squeal until warmed up)
Apikol rear diff mount
034 Differential carrier Mount
034 Snub mount
034 14pc control arm kit and replaced bushings
Thanks for looking
