LS: EPC
012555 - Low Pressure Fuel regulation
P310B - 002 - Fuel Pressure Outside Specification
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 22
Reset counter: 255
Mileage: 172242 km
Time Indication: 0
Freeze Frame:
RPM: 1283 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 13.0°C
Temperature: 15.0°C
Absolute Pres.: 830.0 mbar
Voltage: 14.351 V
001092 - EVAP Purge Control Valve (N80)
P0444 - 004 - Circuit Open - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 172253 km
Time Indication: 0
Freeze Frame:
RPM: 186 /min
Load: 58.4 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 45.0°C
Absolute Pres.: 840.0 mbar
Voltage: 11.049 V
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 004 - Malfunction / Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 172253 km
Time Indication: 0
Freeze Frame:
RPM: 186 /min
Load: 58.4 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 45.0°C
Voltage: 10.668 V
000579 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 004 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 172253 km
Time Indication: 0
Freeze Frame:
RPM: 172 /min
Load: 64.7 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 22.0°C
Voltage: 10.414 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172310 km
Time Indication: 0
Freeze Frame:
RPM: 460 /min
Load: 33.7 %
Speed: 4.0 km/h
Temperature: 99.0°C
Temperature: 42.0°C
Voltage: 12.319 V
001796 - Clutch Switch (F36)
P0704 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172328 km
Time Indication: 0
Freeze Frame:
RPM: 2923 /min
Load: 11.8 %
Speed: 113.0 km/h
Temperature: 96.0°C
Temperature: 31.0°C
Voltage: 13.716 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 172362 km
Time Indication: 0
Freeze Frame:
RPM: 181 /min
Load: 64.7 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 22.0°C
Voltage: 10.541 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004524
Shop #: WSC 06325 000 00000
VCID: 2C50C8FB8F0FD62230-8078
1 Fault Found:
00532 - Supply Voltage B+
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Time Indication: 0
Freeze Frame:
Hex Value: 0x0800
Hex Value: 0x1302
Hex Value: 0x0003
Hex Value: 0x027C
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BQ
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 71EE198F3BADFBCA43-5000
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
29-00 - Short to Ground
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01001
Shop #: WSC 65536
VCID: 3D76F5BF37754FAA97-4A9C
1 Fault Found:
02071 - Local Databus
57-00 - Electric Circuit Failure
