Mark this thread as Unsold
Audi A8 2004 Audi A8 $6,000 Ohio/Indiana border
Old Feb 25, 2019 | 12:25 PM
garysaunders85's Avatar
Default 2004 Audi A8 $6,000 Ohio/Indiana border
160,000 miles.
In the last 10,000 miles this is all that's been repaired.
Email me at garysaunders85@yahoo.com with any questions
Complete timing belt kit, water pump and coolant
Spark plugs and coil packs
Serpentine belt, tensioner and idler pulley assembly
Bufkin pipe changed to steel.
New gaskets for oil cooler
Inner and outer tie rods with new boots.
All exhaust leaks fixed.
All 4 upper control arms
mmi control circuit board
New OEM MAF
Cleaned throttle body and relearn
Air ride shocks with a new compressor
New AGM battery.
Alignment
Trans fluid and filter kit
Oem rotors and hawk street pads and wear sensors on all 4 corners.
2 sets of tires. Summer and winter. 60-75% tread on both.
Brake fluid flush
Engine air filter, cabin air filter
Has the HID lights, 32 adjustable seats, Bose system, flip screen, Navigation. Heated and cooled seats. Front and rear!
The bad. The car has a slight Miss at idle sometimes. I keep getting an oxygen sensor code. When it comes on I clear the code and it goes back to normal for a couple days. OBD eleven shows it reading 0 on bank one until reset. Gonna need replaced.
This winter when it was below freezing temperatures my speakers didn't work but after the car warmed up everything was fine. Happened One Time. Possible new amplifier. Possible!!
Last edited by garysaunders85; Feb 25, 2019 at 12:30 PM. Reason: Forgot phone number
Jim TT
Apr 22, 2003 06:02 PM
