Fans coming on. Suspect relay 219. Change my mind...
Symptoms are, when the battery is connected, after about 10 seconds, the fan comes on. If the door is opened, the fan stops but starts again until the door is closed or starts again anyway after about 30 seconds. If the ignition is switched to "on", the fan stops and doesn't come back on while the ignition remains on. Once the ignition is off, the fan comes on again after about 30 seconds. Pulling fuse 4 stops the fan coming on.
From reading around this and other forums, the finger seems to point squarely at relay 219. I have done a partial inspection of the ECM box and it appears to be in reasonable shape but the inside of the car did have some dampness after the rain. I don't want to pull things further apart (removing wipers, cover etc) as I don't have the relay to hand at the moment and I'd like to get it done in one go since removing the wiper cowl will make the compartment more susceptible to water intrusion and we might have more rain coming in. So what I'm hoping for is if someone can say "No it can't be relay 219 because 'X' from what you described" and I can look somewhere else otherwise.
Thanks in advance.
