Audi A6 1999 A6 Avant for sale Northeast PA
The automatic transmission has developed a common leak at the oil pump, which is beyond my capability of personal repair. The estimate to repair this transmission in Scranton PA is $1,500.00. I must now part with this immaculate car.
I have full records since I bought this car from Louisiana in 2003, which are too numerous to list. Please ask any questions that you may have. I will entertain all reasonable offers. This car now resides in my garage for safe keeping.Please ask any questions that you may have. $2150.00
Here are some highlights of recent maintenance…
- Complete timing belt service 100 miles ago.
- New upper and lower radiator hoses, heater hoses & coolant reservoir.
- New fuel pump
- All new rotors, pads, and calipers.
- Rear suspension: new springs, struts, control arms, bushings, alignment bolts, all fully anti-seized for easy adjustment.
- Perfect alignment achieved: I get 38,000 miles on a set of tires.
- New windshield/headlights washer reservoir, pump and grommets.
- Restored wheels – New Uniroyal tires.
- Sub frame excellent.
- Front control arms replaced as needed.
- Auxiliary air pump hoses new, all vacuum hoses replaced.
- New third brake light assembly.
- New Ignition switch.
- Oil changed every 5,000 miles: Lubrication Engineers Monolec oil only.
- New Beru coil pack, Ignition wires, and Spark plugs.
- New Headlight Assemblies
- New Battery 3/20/19: kept on a maintainer.
- Annual brake fluid changes with ATE Dot 4 fluids.
This car is soon going to need…
- Resonator patch (starting to make noise)
- Right front fender (showing typical rust at outer top lip)
- Currently there is a code stating insufficient air flow detected. The Kombi valves are most likely blocked and the culprit.
- Transmission repair estimated to be $1,500.00
Asking $2150.00 cell phone: 570 780 8414
