Mark this thread as Unsold
Audi A6 2004 Allroad - I dare you to buy this car!
Old Mar 18, 2019 | 02:45 PM
swamper8's Avatar
Default 2004 Allroad - I dare you to buy this car!
2004 Allroad Frankenstein’s monster.
This car started out life as a 2.7T then went to a 4.2L Allroad motor, then 4.2L S4 motor. The last iteration I put this poor car through was a 4.2 belt motor w/A6 front end which I drove for about a year. I’ve since pulled the front apart to return it to a Allroad specs and have officially lost interest. Frame horns have been cut off so I would consider this a parts car unless you’re crazy ambitious. Car has sat for about a year but started immediately. Air suspension came right up and has been holding level for two days.
See list below, this accounts for 90% of the work I did to the car over its life. Obviously anything related to the 2.7T motor is null and void.
Some highlights off the top of my head:
- Factory 6MT so it’d make a good swap donor.
- Rear bags were replaced just before taking it off the road. (Arnott’s) I estimate they have 5K on them.
- Genuine OEM tow hitch. (took me 4 years to finally find one)
- The clutch in this combo is for a 2.7T. New flywheel and clutch. Probably 10K on it.
- Rear driveshaft is also near new with between 10-15K on it.
I have a few bins of random extra parts you can take if you want. title in hand.
If you have some sort of un-diagnosed mental disorder and you like Allroads the parts potential may give you a chubby.
As for me, my doctor finally got my meds balanced correctly and I now own a Toyota.
Make me an offer and bring a trailer.
Purchased 12/3/10
Maintenance/repairs/upgrades:
12/3/10- 12/21/10 - Selling dealer replaced:
Both front bags (arnott)
Air Suspension ECU
Air Suspension Distribution Block
12/23/10 - New battery (interstate MTP-93)
12/23/10 - New Cabin Filter - Purolater
2011
01/01/11 - Oil Changed - Castrol 0W-30 & MANN Filter - 74,765
01/03/11 - Used front ashtray (Shokan)
01/03/11 - Used drivers door latch (Shokan)
01/15/11 - New brake light switch
01/18/11 - Changed plugs - NGK 5458
01/22/11 - Air Suspension Pump - Arnott
03/02/11 - New Exhaust Gas Temperature Sensors
04/09/11 - JHM Timing Belt Kit - belt,tensioner/pulley/waterpump/t-stat etc
04/09/11 - Oil Changed - Castrol 0W-30 & MANN Filter - 79,860
07/16/11 - Oil Changed - Castrol 0W-30 & MANN Filter - 86,955
10/22/11 - Oil Changed - Castrol 0W-30 & MANN Filter - 93,063
10/??/11 - Hotchkis Sway Bars
11/03/11 - New front axles (Raxles)
12/08/11 - Perrin End Links (Front)
??/??/11 - Low temp afterrun temp switch - 021 919 369
ONE YEAR UNDER MY BELT (WHEW)
2012
01/14/12 - Metal thermostat housing, CAM seals, VCG's, afterrun relocation kit
01/20/12 - Electric Fan (replaces cracked plastic viscous fan - *later removed*)
01/21/12 - Oil Changed - Castrol 0W-30 & MANN Filter - 98,563
02/04/12 - Apikol Blue Snub - 07A0238
04/04/12 - Oil Changed - Castrol 0W-30 & MANN Filter - 104,134
05/24/12 - Repaired rear window lock-out switch
05/29/12 - 034 Motorsports "Sport" transmission mounts
07/07/12 - Altrom fan & Imperial fan clutch installed. "S4 setup" (EFK removed)
09/15/12 - Oil Changed - Castrol 0W-30 & MANN Filter - 111,992
09/29/12 - Front Brakes - New OEM rotors and Hawk Pro Ceramic pads
09/30/12 - New rear diff. flange oil seals and new synthetic 75W-90
10/05/12 - Front/lower/rear control arm bushings (Napa)
12/26/12 - Oil Changed - Castrol 0W-30 & MANN Filter - 118,842
2013
03/30/13 - New rear rotors (Napa) and Hawk Pro Ceramic pads
03/30/13 - Oil Changed - Castrol 0W-30 & MANN Filter - 125,973
07/10/13 - Oil Changed - Castrol 0W-30 & MANN Filter - 133,997
12/07/13 - Oil Changed - Castrol 0W-30 & MANN Filter - 142, 867
2014
03/25/14 - Oil Changed - Castrol 0W-30 & MANN Filter - 149,228
04/19/14 - Replaced exhaust flex joints
04/19/14 - Replaced Coolant Temperature Sensor O-Rings
05/17/14 - Replaced Upper and Lower control arms (OEM & TRW)
05/18/14 - Replaced Hazard/Flasher module
05/24/14 - Replaced outer tie rod ends
05/24/14 - Replaced Front/Right suspension air bag (Arnott GEN I)
05/26/14 - New tires - Continental DTS Extreme Contact (OEM size)
08/18/14 - Oil Changed - Rotella 5W-30 & MANN Filter - 158,504
12/21/14 - Oil Changed - Castrol Syntec 5W-30 & MANN FIlter - 165,977
12/21/14 - Replaced oil temperature sensor (165,977)
2015
10/10/15 - Replaced front Rotors (Zimmerman) and front pads (Hawk)
10/10/15 - Installed used passenger side CAM tensioner solenoid
12/06/15 - Replaced Serpentine belt
??/??/16 - Replaced transmission fluid
07/04/16 - Replaced both EGT sensors
07/13/16 - Replaced cracked TBB (OEM)
08/12/16 - Replaced front/right wheel bearing (Altrom)
09/01/16 - Replaced both emergency brake cables (aftermarket)
09/07/16 - Replaced damaged Headlight switch (bezel only-China special)
09/07/16 - Replaced fuel filter - MANN WK725
09/14/16 - Replaced fuel pump assembly (VDO)
09/17/16 - Replaced right/front air spring (Arnott)
09/25/16 - Replaced fuel pump relay (OEM)
09/25/16- Replaced air suspension relay (OEM)
10/01/16 - Replaced front rotors (Napa premium)
10/01/16 - Replaced front pads (Akebono Ceramic)
10/11/16 - Replaced drivers door latch assembly (OEM)
10/11/16 - Replaced drivers door lock cylinder rod
*** 10/16/16 - 200,000K ***
10/20/16 - Replaced starter (reman bosch)
10/20/16 - Replaced engine mounts (034 motorsports street density)
10/22/16 - Complete timing service:
- Continental timing belt
- OEM tensioner/rollers/tensioner arm
- Water pump w/metal impeller
- Thermostat
- Serpentine belt tensioner
10/22/16 - Oil Changed - Castrol Syntec 5W-30 & MANN filter - 200,087
12/01/16 - Rear coolant supply hose o-ring
12/08/16 - Replaced rear air springs (Arnott GEN I's)
2017
01/02/17 - Replaced right/rear caliper (leaking brake fluid)
01/08/17 - Replaced center support bearing (driveshaft)
01/26/17 - Replaced rear driveshaft assembly - Powertrain Industries - 2594-131
FEB/MAR 2017 - Converted car to 4.2L B6S4 motor w/6MT (factory 01E)
Replaced:
- All coolant pipe O-rings
- Thermostat and housing seals
- water pump and seals
- serpentine belt
- serpentine belt idler
- serpentine tensioner assembly
- Valley pan gasket and oil check valves
- 6 timing guides
- Replaced power steering pump (used)
- Installed new AC condenser & high pressure switch
- Installed new starter
June/July 2017 - Converted car to 4.2L AWN Belt motor w/6MT (factory 01E)
Old Mar 25, 2019 | 08:01 AM
swamper8's Avatar
SOLD
