A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
P2404 issue 2008 audi a4
Old Mar 23, 2019 | 01:35 PM
Two4twentysam's Avatar
Default P2404 issue 2008 audi a4
Hi all. I just wanted to post my experience with the fault code P2404. Right to the solution in my case was a vacuum hose leak.
Now for the long answer. i have a 2008 audi a4 ive owned since i purchased new. My sister has had it for about 2-3 years though. Anyways she moved to Florida and i moved to Washington and just had the car shipped my way. Before she sent it off we had Audi in Pensacola Fl did a diagnostic. according to them it needed a serp belt tensioner and an issue with the evap leak detection pump. They wanted $1600 for both. had it shipped and started working on it myself. As i was googling i found a ton of results as to what it might be. The tensioner was fixed for about $30 and 10 min time. The evap was harder to figure out. N80 valve was the most popular result it seamed. I bought one from oreilly for like $20-30 but didnt put it in. I think i read something like if it failed it would have been from something else. Seen a test somewhere that said to take it off and blow through it. I just decided it was fine and looked for other problems. My old mechanic who is a wizard told me over the phone to check for vacuum leaks. Specifically to the brake booster. After 2 minutes looking around i found a small vacuum line to the break booster and also running through the top of the firewall. The boot going into the intake manifold was ripped about 1/2 way around and it has a little line coming out the bottom. Looks like someone in the passed j-b welded it together. I guess at some point someone fixed an issue in that way. $100 for a new hose from advanced auto parts and a code delete. Havent had an issue since. I just got a vcds sccan tool and tested the system. All is good. I hope someone sees this and may find it helpful.
Old Feb 15, 2020 | 08:48 AM
patmanj's Avatar
Default Similar issue, question
This piece right here, I cant seem to find. I order this part, but it doesnt seem to be exactly the same.
This plastic part on the bottom is broken.
Any advice finding the correct part or other fix?
Thanks
LongHairedFreakyPeople
Sep 28, 2020 12:06 PM
travisnking
Oct 1, 2014 05:37 AM
brilla
Sep 14, 2010 02:07 PM
StormChaser404
Aug 27, 2003 09:18 PM
JohnK
Nov 18, 1999 08:23 AM
