A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Anyone with an A4 B7 3.0 TDI, please help!
Old May 7, 2019 | 02:44 AM
aurumdeus's Avatar
Default Anyone with an A4 B7 3.0 TDI, please help!
Hi! So, I've been having ongoing issues with my DPF. Long story, but basically it came up clogged, a garage removed it and had it chemically cleaned, and then remounted it. Still producing code P242F and engine in limp mode.
There is a huge difference between the two soot measurements (MB 104.2 and 104.3). The measured differential pressure across the DPF looks pretty low to me even at higher RPMs, although I don't have anything to compare it to.
The dealership wants to replace the DPF at a cost of over €3,000(!) but aren't being forthcoming at all with information, so I want to be sure that it is actually in need of replacement.
If anyone has the same engine (ideally BKN engine) and isn't having DPF issues, could you create the same graph as I did so that I can compare the two?
The car was sat in neutral, sitting at idle with me then raising the RPM to a little under 3k (max I could do with the limp mode), and dropping again.
With this screenshot you can see that even at 3k RPM the engine was showing a differential pressure of 62mbar, with one of the carbon values at 2g while the other is locked at over 70g.
Thank you in advance for any help that anyone can give!
TeamHate
May 28, 2019 08:54 PM
Perica
New Member Welcome Area
Jul 31, 2018 12:51 PM
mechengr
1.8T Discussion
Jul 6, 2008 04:47 AM
duffman1101
Sep 3, 2003 07:36 PM
Nels
Audi 100 / A6 (C4 Platform)
Aug 27, 2002 09:01 AM
