Audi Q5 FS in Wash DC: 2015 PRESTIGE with cooled seats, S-line, 80k mi
WA1WGAFP3FA068533 -- https://www.audiworld.com/forums/vin...WGAFP3FA068533
Mechanical & Powertrain
Engine: 3.0 TFSI 6 Cylinder 272 HP
3.20 Axle Ratio
GVWR: 5,622 lbs
Full-Time All-Wheel Drive
Engine Oil Cooler
150 Amp Alternator
80-Amp/Hr Maintenance-Free Battery w/Run Down Protection
1047lbs. Maximum Payload
Gas-Pressurized Shock Absorbers
Front And Rear Anti-Roll Bars
Electric Power-Assist Speed-Sensing Steering
19.8 Gal. Fuel Tank
Quasi-Dual Stainless Steel Exhaust w/Polished Tailpipe Finisher
Permanent Locking Hubs
Multi-Link Front Suspension w/Coil Springs
Multi-Link Rear Suspension w/Coil Springs
4-Wheel Disc Brakes w/4-Wheel ABS, Front And Rear Vented Discs, Brake Assist, Hill Descent Control and Electric Parking Brake
Brake Actuated Limited Slip Differential
Safety
Side Impact Beams
Low Tire Pressure Warning
Dual Stage Driver And Passenger Front Airbags
SIDEGUARD Curtain 1st And 2nd Row Airbags
Airbag Occupancy Sensor
Rear Child Safety Locks
Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point, Height Adjusters and Pretensioners
Interior
Driver Seat
Passenger Seat
Manual Tilt/Telescoping Steering Column
Gauges -inc: Speedometer, Odometer, Engine Coolant Temp, Tachometer, Oil Level and Trip Odometer
Leather Steering Wheel
Rear Cupholder
Front Cigar Lighter(s)
Ashtray
Compass
Valet Function
Power Fuel Flap Locking Type
Remote Releases -Inc: Power Cargo Access
HomeLink Garage Door Transmitter
Cruise Control
HVAC -inc: Underseat Ducts and Console Ducts
Illuminated Locking Glove Box
Driver Foot Rest
Full Cloth Headliner
Leather Gear Shift ****
Day-Night Auto-Dimming Rearview Mirror
Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination
Full Floor Console w/Covered Storage, Mini Overhead Console w/Storage and 4 12V DC Power Outlets
Front And Rear Map Lights
Fade-To-Off Interior Lighting
Carpet Floor Trim
Trunk/Hatch Auto-Latch
Cargo Area Concealed Storage
Rigid Cargo Cover
Cargo Features -inc: Spare Tire Mobility Kit
Cargo Space Lights
Refrigerated/Cooled Box Located In The Glovebox, Driver / Passenger And Rear Door Bins and Audio Media Storage
Delayed Accessory Power
Redundant Digital Speedometer
Outside Temp Gauge
Analog Display
Manual Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints
2 Seatback Storage Pockets
Perimeter Alarm
Engine Immobilizer
Air Filtration
Exterior
Steel Spare Wheel
Compact Spare Tire Mounted Inside Under Cargo
Clearcoat Paint
Body-Colored Front Bumper
Body-Colored Rear Bumper
Chrome Side Windows Trim and Black Front Windshield Trim
Body-Colored Door Handles
Body-Colored Power Heated Auto Dimming Side Mirrors w/Power Folding and Turn Signal Indicator
Fixed Rear Window w/Fixed Interval Wiper and Defroster
Deep Tinted Glass
Speed Sensitive Rain Detecting Variable Intermittent Wipers w/Heated Jets
Galvanized Steel/Aluminum Panels
Lip Spoiler
Chrome Grille
Power Liftgate Rear Cargo Access
Front And Rear Fog Lamps
Perimeter/Approach Lights
LED Brakelights
Programmable Projector Beam Headlamps w/Washer and Delay-Off
Tech Specs
Vehicle NameAudi Q5
Body Style
quattro Sport Utility
Drivetrain
All Wheel Drive
EPA Classification
Small Sport Utility Vehicles 4WD
Passenger Capacity
5 5.0 min 5.0 max
Passenger Volume
101.5 ft³ 101.5 min 101.5 max
Base Curb Weight
4365 lbs 4365.0 min 4365.0 max
Fuel Economy Est-Combined
21 MPG 21.0 min 21.0 max
EPA Fuel Economy Est - City
18 MPG 18.0 min 18.0 max
EPA Fuel Economy Est - Hwy
26 MPG 26.0 min 26.0 max
Dead Weight Hitch - Max Trailer Wt.
4400 lbs 4400.0 min 4400.0 max
Dead Weight Hitch - Max Tongue Wt.
440 lbs 440.0 min 440.0 max
Wt Distributing Hitch - Max Trailer Wt.
Wt Distributing Hitch - Max Tongue Wt.
Maximum Trailering Capacity
Engine Type
Intercooled Supercharger Premium Unleaded V-6
Displacement
3.0 L/183
Fuel System
Gasoline Direct Injection
SAE Net Horsepower @ RPM
272 @ 4780
SAE Net Torque @ RPM
295 @ 2150
Trans Type
8 8.0 min 8.0 max
Trans Description Cont.
Automatic w/OD
First Gear Ratio (:1)
4.71 4.71 min 4.71 max
Second Gear Ratio (:1)
3.14 3.14 min 3.14 max
Third Gear Ratio (:1)
2.11 2.11 min 2.11 max
Fourth Gear Ratio (:1)
1.67 1.67 min 1.67 max
Fifth Gear Ratio (:1)
1.28 1.28 min 1.28 max
Sixth Gear Ratio (:1)
1.00 1.0 min 1.0 max
Reverse Ratio (:1)
3.32 3.32 min 3.32 max
Final Drive Axle Ratio (:1)
3.20 3.2 min 3.2 max
Tons/yr of CO2 Emissions @ 15K mi/year
8.4 (Est)
Maximum Alternator Capacity (amps)
150 150.0 min 150.0 max
Suspension Type - Front
Multi-Link
Suspension Type - Rear
Multi-Link
Suspension Type - Front (Cont.)
Multi-Link
Suspension Type - Rear (Cont.)
Multi-Link
Front Tire Size
P255/45WR20, P235/55HR19
Rear Tire Size
Spare Tire Size
Compact
Front Wheel Size
20 X 8.5, 19 X 8 in
Rear Wheel Size
20 X 8.5, 19 X 8 in
Spare Wheel Size
Compact in
Front Wheel Material
Aluminum
Rear Wheel Material
Aluminum
Spare Wheel Material
Steel
Steering Type
Rack-Pinion
Turning Diameter - Curb to Curb
38.1 ft 38.1 min 38.1 max
Brake Type
4-Wheel Disc
Brake ABS System
4-Wheel
Disc - Front (Yes or )
Yes
Disc - Rear (Yes or )
Yes
Front Brake Rotor Diam x Thickness
13.6 in 13.6 min 13.6 max
Rear Brake Rotor Diam x Thickness
13 in 13.0 min 13.0 max
Fuel Tank Capacity, Approx
19.8 gal 19.8 min 19.8 max
Front Head Room
39.4 in 39.4 min 39.4 max
Front Leg Room
41 in 41.0 min 41.0 max
Front Shoulder Room
57.7 in 57.7 min 57.7 max
Second Head Room
39 in 39.0 min 39.0 max
Second Leg Room
37.4 in 37.4 min 37.4 max
Second Shoulder Room
56.4 in 56.4 min 56.4 max
Wheelbase
110.5 in 110.5 min 110.5 max
Width, Max w/o mirrors
74.7 in 74.7 min 74.7 max
Height, Overall
65.2 in 65.2 min 65.2 max
Track Width, Front
63.7 in 63.7 min 63.7 max
Track Width, Rear
63.5 in 63.5 min 63.5 max
Min Ground Clearance
7.9 in 7.9 min 7.9 max
Liftover Height
27.3 in 27.3 min 27.3 max
Cargo Volume to Seat 1
57.3 ft³ 57.3 min 57.3 max
Cargo Volume to Seat 2
29.1 ft³ 29.1 min 29.1 max
Cargo Volume to Seat 3
Seventh Gear Ratio (:1)
0.84 0.84 min 0.84 max
Eighth Gear Ratio (:1)
0.67 0.67 min 0.67 max
Model Group
Q5
Vehicle Segment
Compact Luxury Sport Utility
Vehicle Type
Sport Utility
Engine Displacement Units
3.0, 3.0 3.0 min 3.0 max
Engine Camshaft
DOHC, DOHC
Engine Block Type
aluminum, aluminum
Engine Cylinder Count
6, 6 6.0 min 6.0 max
Engine Valve Count
4, 4 4.0 min 4.0 max
Country of Origin
Germany Pkw
