Mark this thread as Unsold
Audi A4 2004 Audi A4 1.8T Ultrasport Quattro Avant.
Old Aug 4, 2019 | 06:34 PM
Lucky736's Avatar
Default 2004 Audi A4 1.8T Ultrasport Quattro Avant.
Selling my Avant. It is a genuine Ultrasport Avant. It has spent life in CA and TX. It does not see inclement weather, ironically. Miles are 157k now. Just completed a 4k plus mile trip. Updated Pics and Price as well.
I own multiple vehicles and this one gets used when it's utility is needed however it hasn't been a daily in a while. I'd like to see it find a good home.
It recently had an inspection done and issues other than what is mentioned at the very bottom have been taken care of. All work has been done by a Certified VW/Audi Mechanic.
Service During My Ownership, 2013-Present and from 127k on, Sorted from First to Most Recent:
Replaced 4 Tires NEW Goodyear Eagle Sport 245/40/18
Performed 4 Wheel Alignment
Replaced Coolant Flange
Replaced Coolant Temp Sensor
Replaced Coolant Temp Sensor Clip
Replaced Related Rubber O-Rings
Replaced Cam Tensioner Gasket
Replaced Cam Tensioner Seal
Replaced Valve Cover Gasket
Replaced Motor Mounts
Replaced Snub Mount
Replaced Passenger Front Inner CV Boot
Replaced Passenger Front Outer CV Boot
Replaced Axle Nut
Replaced License Plate Lamp Assemblies
Replaced Armrest Lid Assembly
Repaired Rear Hatch Actuator
Replaced Coolant Overflow Tank Cap
Replaced Oil Dipstick Tube
Replaced Engine Air Filter
Replaced Cabin Air Filter
Replaced Front Brakes
Replaced Rear Brakes
Replaced Fuel Filter
Replaced All Spark Plugs
Replaced Tail Lamp Bulb
Installed 034 Billet Oil Breather Adapter
Performed PCV Simplification
Removed PCV Valve
Removed PRV Valve
Routed Valve Cover and Oil Breather Tube to Vent to Air
Repaired Clogged Rear Washer Nozzle
Repaired Clogged Front Washer Nozzle
Replaced Main Engine Fan
Replaced Auxiliary/AC Condenser Fan
Replaced Upper Radiator Three Way Hose
Lubricated Sway Bar Bushings
Replaced Rear Hatch Struts
Replaced Battery w/ Interstate Mega Iron Plus Battery 2/2018
Replaced Plastic Coolant Screw w/ Metal Replacement 11/2018
Replaced Driver Front Inner CV Boot 11/2018
Replaced PCV Vacuum Suction Jet Pump 2/2019
Replaced PCV Check Valves Top of Intake Manifold 2/2019
Replaced PCV Hoses Top of Intake Manifold 2/2019
Replaced Fuel Filter 6/2019
The car has some minor issues:
-The rear of headliner in the cargo area has sagged.
-Small tear in the driver bolster.
-A few years ago the AC was charged. It is low on refrigerant again. The AC components, including compressor, are confirmed to be working.
The car has an aftermarket Denison Bluetooth/iPod/iPhone Module installed.
Album with additional pictures: https://flic.kr/s/aHskFy21eU
$9,000
Old Aug 6, 2019 | 06:18 PM
jaustin's Avatar
wow, almost took a spill outta my chair when I got to that bottom number.
Old Aug 6, 2019 | 10:05 PM
kinderutz's Avatar
I sprayed coffee all over me when I saw the price..OMG
Old Aug 7, 2019 | 07:17 AM
Lucky736's Avatar
That sucks, don't burn yourself. Careful out there.
sandorck
Mar 26, 2017 10:45 AM
OzzyLime
Nov 15, 2011 04:11 AM
Jon-1.8t
Jan 12, 2009 09:51 AM
audi-hitman
25
Feb 23, 2007 09:17 AM
CEB
Feb 19, 2005 02:17 PM
