b5 Audi A4 Quattro Rear Knuckle Assembly
I'd like to buy it off someone here possibly if anyone has a parts car or anything just because I'm tight on money right now and I can't really afford to drop $110 on this.
I need it to also include the wheel bearing. I don't care if it includes the bushings for the camber bolt or not. Preferably not because I have the bushings already.
[Explanation] Went for an alignment and my camber was off and the bolts were seized so they couldn't do an alignment, I took the project on myself and broke the camber bolts off and sawzalled through them to seperate the knuckle from the a arm but I'm not able to get these stupid bushings out of the knuckle and they're burnt and shot now from the heat of getting the camber bolts out. Not to mention they also have a rust welded camber bolt stuck in them. I was going to completely take the knuckle off so I could work on it easier and get these stupid bushings out so I can put the new ones in along with a new bolt but my tiny bolt for the speed sensor broke off inside of the knuckle. I'm also in need of a new wheel bearing on that same wheel, so I say why **** with it I'll just get a whole new knuckle assembly so I don't need to drill out my speed sensor bolt, it can come with a new good wheel bearing, and it'll have the camber bolt out so I can just re install it without messing with anything else and get my alignment.
Thanks, If I can't find anything might look around craigslist for a parts car.
