Audi A6 Audi Avant A6 1999
The following items have been replaced:
-ABS control unit (on pump)
-radiator assy
-power steering pump
-power steering feed flex hose 2019
-front seats for a 2003 donor
-trans right side output seal
-updated later passenger side mirror (larger)
-both catalytic converter (oem)
-oxy sensor within the last year or so
-all vacuum lines plastic and rubber in engine bay (within the last year or so)
-oem throttle body 2-3 years ago
-front control arms upper and lower all relatively new and oem
-rebuilt rear brake calipers within the last 2-3 years
-master cylinder oem
-outer and inner tie rod end assy (oem) within the last 2-3 years
-sway bar links oem (4-5 years)
-rear shock absorbers (4-5 years) oem
-center muffler assy 2019
