Audi A6 Audi A6 Avant 2006 loaded (Tech+Prem Pkg) in VA
The car is beautiful - clean inside and out, with only a few small scratches touched up by previous owners.
Asking $4200 OBO
Year: 2006
Model: A6 Avant
Miles: 158,000
Engine: 3.2L FSI V6
Upgrades:
Dension GW500S BT Bluetooth and iPod gateway integrated as a second CD changer – stream music via Bluetooth or USB
Brand new Thule aero roof bars with locks and keys
Covercraft windshield sunshade custom fit for A6
Upgraded Audi S6 wheels in great shape
Osram 66240NB Xenarc D2S Nightbreaker headlight bulbs
Recent services performed:
Replaced Engine stop/start switch with genuine part (newer style with silver button)
Replaced both tailgate struts
Updated Navigation DVD to 2015/2016 version
Replaced fuel filter
Replaced power steering fluid with correct Pentosin CHF202
Replaced air filter
Cleaned MAF and throttle body
Replaced battery with AutoZone Platinum AGM
Audi of Charlottesville performed Takata airbag recall
Alignment
Several oil changes with Liqui Moly 5W40 synthetic oil and Mann filter
New genuine Audi gas cap
Replaced all four cam position sensors
Replaced three VVT solenoids
Replaced 5 ignition coils
Replaced front rubber engine mount
Replaced spark plugs
Replaced valve cover gaskets and valve cover bolts, and cam girdle (retaining frame) gaskets
Replaced both upper timing chain tensioners
Installed Dimple magnetic oil pan drain plug
Replaced evap purge valve
Replaced cabin air filters
Known issues:
Automatic tailgate is a little weak and needs some help lowering
Lower section of passenger door is flaring out a little
Sometimes hesitates on initial takeoff
One parking sensor not working
Check engine light for cam position sensor / VVT issue (P0366) - I have re-checked the timing and it seems to be perfect so I don't know why this code won't go away. The car is drivable but this code does cause the car to not have full power since the VVT does not properly engage.
Bluetooth/iPhone is CD7
