Mark this thread as Unsold
Audi A4 2006 Audi A4 Avant 2.0T Quattro .........$5,500 (Boise, ID)
Old Nov 1, 2019 | 07:57 AM
kinderutz's Avatar
Default 2006 Audi A4 Avant 2.0T Quattro .........$5,500 (Boise, ID)
VIDEO LINK:
For sale today is my super clean 2006 Audi A4 Avant Quattro 2.0t with the cold weather and sport package that's as clean as they come and fully loaded (leather, BOSE, anti-dazzle mirrors, wood trim, heated seats, etc.)
There are 165k miles on this mint A4 and in October 2019 it received the following:
- new timing belt
- new timing components (roller, tensioner, water pump)
- new timing chain and chain tensioner (between the cams)
- new timing cover gasket (at the back of the cylinder head)
- new vacuum pump
- new valve cover assembly
- new valve cover gasket
- new motor mounts
- new breather valve
- new spark plugs
- new air filter
- new cabin filter
- new HPFP (high pressure fuel pump)
- new cam follower
- new coolant flange
- new temp sensor
- new map controlled thermostat
- new pads and rotors all around
- new transmission filter and synthetic fluid
- new control arms
- new sway bar links
- new inner tie rod (pass side)
- new oil and filter (5w40 synthetic)
- new coolant (OEM G13)
- new OEM front and read wiper blades
- new Weather Tech all weather floor mats and matching trunk liner
- FULL CARBON CLEANING
Everything works as it should, all readiness monitors are set, no pending fault codes, passes emissions testing with flying colors. No squeaks, no leaks, no clunks, no hidden surprises, this Avant is the real deal and very fun to drive.
Fly in and drive home, I will gladly pick you up from the Boise airport.
I would not hesitate to drive this car from coast to coast at any given time, it's SOLID.
The car comes with 2 keys and a 1 inch thick folder of maintenance records.
Fairly priced at $5,900 (NOW $5,700.....NOW $5,500) this wagon will not disappoint, you have my word.
Clean Carfax and clean Idaho title in hand with my name on it.
The Audi Guy
267.984.three five seven nine
Old Nov 3, 2019 | 07:24 AM
kinderutz's Avatar
Willing to take $5,000 for the wagon.
Old Nov 3, 2019 | 11:23 AM
KevinGary's Avatar
Community Builder
Boy have you done an awful lot of work on the car. GLWS
Old Nov 3, 2019 | 01:21 PM
kinderutz's Avatar
Thank you, this A4 is SOLID and will not disappoint....nothing was left untouched.
No warning lights, no pending codes, no leaks, no squeaks, no hidden surprises.....if it makes any difference I am a factory trained, master Audi tech....just google "The Audi Guy"
the_tig
Nov 7, 2019 07:18 AM
kinderutz
Aug 22, 2019 05:48 AM
Devin Sezgen
Aug 4, 2019 10:38 PM
Neil Davidson
Mar 28, 2019 02:05 PM
searock
Dec 19, 2017 06:11 AM
