Mark this thread as Unsold
Audi Other Exceptionally clean 1995 urS6 avant 202K miles
Old Nov 7, 2019 | 04:11 PM
jjm's quattro's Avatar
Default Exceptionally clean 1995 urS6 avant 202K miles
Second owner, bought in January 2001 (with 48K). Always garaged and undercarriage cleaned after occasional winter driving. Check photos ofsuspensioncomponents andfuel lines. There has never been any rust onfenders,doorjams, etc. The car is in exceptional condition. It has been driven enthusiastically and thoroughly enjoyed, including ski trips and cross-country drives, but never abused. Third, rear-facing, seat for two children folds under rear cargo area. It has been removed to provide additional storage for travel, but the car comes with this seat and all hardware, and it can be easily bolted back in place.
In all aspects of driving and handling plus appearance Inside and out this car does not look like it is 25 yr old.
Asking price $9500. This car can be seen and test driven in either Arlington, MA or Francestown, NH. Email: sueandjim.mccarthy@gmail.com subject UrS6 avant.
Regular maintenance, includingoilchange (synthetic - mostlyMobil1) and largefiltersat about 3000 mile intervals.PentosinNFcoolantchanged every few years.Brake fluidflushed with everybrakeservice. Some items listed below were replaced because it was convenient when other repairs were in progress.
Koni adjustable shocksandstrutswith 1992 sport frontsprings, and genuine Euro Avant sportrear springs(for proper avant rear height). This configuration provides an ideal combination for handling and ride height. (Note correct color coding for theserear springsin photos.) HID VVME low beams. Euro lenses with clear film protection. Saamcoboosthoses, metalcrossoverpipeandintercoolerwithmetal ends. Extendiblehoodstrut.Powder coated valve coverand rare billet aluminuminjectorcoverwith four rings. Sidemirrorsare without any delamination.
In 2014 a minor bump put a small dent in theLF fenderand cracked the frontbumper. Body work was done at legendary Dicks Auto Body (Cambridge, MA). Newbumperwas sourced from Canada, Dicks produced an excellentpaintmatch, and due to an earlierpaintrepairon driverdoor, I decided to have thempaintthe full left side.
XPEL clear filmon front and rearbumpersand nose. There are a few very small rock chips on the nose under the XPEL. In addition to a couple of very smallparkinglot dings, there are a few light lines of scuff on the passenger side of the frontbumperthat can be seen in an enlarged view of the photo for this corner.
Fuchs 16x8 OEwheelsfinished in Wurth silverpaint.MichelinPilot Exalto with uniform 8/32 tread on all fourtires
148K -- rearsuspensionrefresh. New bushings Apikol poly (all that were available) +Audi, & Blau for others, and new differential out-putshaftseals andCV boots.
184 - 187K -- Rear rotors (Zimmerman) &pads(Akebono), rear camber links (Febi), front tie rod ends (Audi)
Full timingbelt service. Newbolt(Audi),water pump(Hepu), Idler pully (Audi), T belt &serpentine belt(Continental), thermostat (Wahler), thermostatcover(Audi), plastic T & rear blockcoolantadapter(Audi); plugs (F5DPOR);voltage regulator(Bosch); steelthrottlecam (034); full flush withPentosinNFcoolant.
Rewired hatch with new OEharness(Audi). Hatchstruts(Stabilis)
Right-Click switchbladekey
Motorand trannymountsstreet density (034)
192 - 193k -- Frontsuspensionrefresh. Powder coated strut towers, *** (Canada)wheelbearings, new copper sleeves forABSsensors, control arms (Audi),sway barbushings (Audi), servicedCV joints, new outer boots (Audi), inner boots (GKN), subframe bushings street density poly (AK), strutbearings(Febi), servicedcalipers, boots, guide pins (TRW), & new rubber lines.
Six speedtransmission(01E), with 0.56 final gear that allows for an 800RPMreduction during highway cruising, quieter and more fuel efficient.Audishift **** fromdieselmodel with E in 6th position.
Fullclutchkit(Luk), slavecylinder(Sachs)
Rebuilt starter (Bosch)
Mintex frontbrake pads
Rebuiltsteeringrack (Jorgen) andSteeringdamper (Boge)
Newradiator(Langeran & ReichAudiOE)
RT cleaned and testedinjectors
Replaced all low pressure lines in brake/steering system, replacedbrakepressure accumulator and magnafinefilterplusPentosinPS fluidflush.
Within last 1000 miles,oilchange, compression check (see photos), and newBosch plugs(F5DPOR). Currentbrake padcondition front Mintex 12 mm, rear Akebono 10 mm (see photos).
One of the originalcoilswas replaced due to misdiagnosed POS failure. The other four are original. Somecoilsmay be getting weak, but there is no miss underboost. The car comes with 5 new OE BeruCoilsand appropriate electricalconnectorsfor replacing stockcoilsandharness. I have not replaced thecoilsin the event the new owner would prefer to go with anaftermarket coil kit.
With only two exceptions, the drivers seat bottomheater, and thealarmbeep when the car is locking, everything functions as it should, includingcruise controland AC.
Spare parts that go with car at asking price:
Set of ecrufloor matswith four rings. Very clean but foam backing is gone - some owners have replaced the backing
Set ofwinter floor mats, cargo mat, and cargo net
Four refinished (polished lip)OEMFuchs 16 x 8wheels
FourOEMAvus 16 x 7.5wheels(minor curb rash)
Good L & R stockcatalytic converters, plus full spare stockexhaustfromturboback
All leather from ecru front passenger seat and foam bolsters, in excellent condition, components of which can be swapped onto drivers seat.
Pair of black powder coatedroof rails.
Link to Photos: https://photos.google.com/share/AF1Q...FNdTFzSTh2blhn
Global Autosports
May 9, 2012 12:39 PM
XcellR8edAudi
Quattro: Turbo / Ur / Sport
Aug 2, 2004 06:18 PM
The Turtle
Feb 26, 2004 01:49 PM
