Electronic Throttle - tech info?
I'm trying to get involved with the Formula SAE team at my school(http://metweb.spsu.edu/sae/initial.htm). They were talking about coming up with a new throttle body system, so I took this thing apart, diagrammed it, and measured resistances of what looks like a control system.
The idea is to develop a throttle system that open viariably in relation to pedal position. For example, at 50% pedal, the throttle pos. would open slowly to 25%. Then from 50% to 100% pedal, the throttle would accelerate toward 100%. If you were to plot a graph x=pedal pos., y=throttle pos. the graph would be a curve concave upward. The slope would be less than 1 until x=50%, at which it would be 1 and rise from there until 100%. The idea is to give a more linear throttle response from a butterfly style throttle body.
I've spent a good 3 hours searching through forums (here, audiforums, VAG-COM yahoo group, google, etc.) looking for some technical data on the system and perhaps a wiring diagram. There are 6 pins on the throttle body. I found that 2 (pins 3 and 5) are + and - for the servo motor, and 4 (pins 1, 2, 4, and 6) lead to the variable resistor array which follows the butterfly. It looks like pin 6 is reference voltage and the other 3 will show voltage with relation to throttle position. The resistance ranges vary, and some are curved. What I am trying to figure out is what info this array is giving the ecu about the throttle's position, and how it interprets that information and drives the motor in the throttle body, of course with dependency on throttle pos. input.
Does anyone have a service manual with this kind of info, or anyone/anywere to go for info on this system?
I'm not all that familiar with the system yet, but we're using Haltec fuel management.
if I ever come across another running Audi, I'm gonna probe it
good to hear your involved in it, good stuf
