Is this how the nylon tube sits in the t-fitting?
Old Oct 9, 2005 | 10:30 AM
mattarios2's Avatar
Member
Default Is this how the nylon tube sits in the t-fitting?
<center><img src="http://pictureposter.audiworld.com/90165/p1010055.jpg"></center><p>Can anyone explain to me how the nylon tube will get an acurate reading if it is only sitting in the black tubing and not actually over the t fitting nipple?
Thanks
Old Oct 9, 2005 | 10:34 AM
Audi2ptzero's Avatar
Elder Member
Default You dont even need to use the nylon fitting, you can just run rubber vac line from the T fitting
to the back of the gauge.
Old Oct 9, 2005 | 10:41 AM
mattarios2's Avatar
Member
Default but where does it fit to the back of the boost gauge? It seems ...
to only fit that thin of a wire, and not that thick vac line tubing
Old Oct 9, 2005 | 10:45 AM
gh0st's Avatar
Default you have to make a big hole to get that into the vent though
not like you see it but no reason to. It doesn't have to be fitting over the t-fitting as long as air is flowing through there its fine. Just put a couple inches of the nylon tubing into the rubber tubing and put 2 or 3 zip ties on there so your sure you have a good seal
Old Oct 9, 2005 | 10:46 AM
Elder Member
Default Easy, you dont put the big brass fitting on. The gauge should have a treaded fitting already
which you just slip the rubber vac line over.
mattarios2's Avatar
Member
alright great thanks
Old Oct 9, 2005 | 10:49 AM
Elder Member
Default small or big hole it doesnt matter. Why make more spots for it to leak by using a line inside
another? If your going into the middle vent, you just remove the cluster and drill a hole into the vent tube from there, if your afraid of losing cold air thru that hole then use a rubber grommet. I have 3 gauges in my center vent and all my lines come in from there.
Old Oct 9, 2005 | 10:59 AM
gh0st's Avatar
Default your right
Although I haven't had any leaking issues with mine yet
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 9, 2005 | 12:35 PM
BSK's Avatar
BSK
Default Mattarios dont you have anybody living close to your area that is active on AW
it seems like you need a mentor that could teach you some basics about certain things. i hope that by the end of this project you will know some things about vacuum lines and the basics of cable routing and stuff
Old Oct 9, 2005 | 01:43 PM
gh0st's Avatar
Yeah, where do you live?
