ABS rotor question
1 Fault Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
Ordered an ABS sensor (the same as the old one). Replaced the old one. Cleaned the code. Drive the car. The same code comes again in within one minute.
Seems not a problem of the sensor. Want to check the ABS rotor (ring). Looked into the Bentley manual. It seems only the bolt at the center of the wheel need to be taken off. It has an allen socket for my car.
But when looked at the car after taking off the wheel, many things a attached together. I am asking myself if I have to take everything appart. Anyone can tell me how to take it off? Furthoremore, what is the size of the allen
socket?
Thanks!
I don't think I've ever seen a problem with an ABS ring (except where it was completely missing). Have you double checked the connector and did you clean out the sensor hole with a wire brush to make sure it was making a good ground?
Also, if you check the Bentley manual, I believe there is a procedure for checking the connector for an appropriate voltage/ground. You'll want to do that to make sure it's not just a wiring issue (chafed wire somewhere between the connector and ABS controller). If everything else checks out OK, it's a faulty ABS controller.
Cheers,
wheels. Left side is a 8d0-927-807-f, and right side is a 8d0-927-807-c. So, I cannot swap them due to the ground problem.
Cheers,
I'd try to loosen the axle bolt and turn the wheel out and try to take a peek that way. But I'd also exhaust all other options before doing that.
