Where's the starter relay?
Old Oct 10, 2005 | 03:56 AM
computrtutr's Avatar
Default Where's the starter relay?
1.8T, Q, Stick, sedan.
I'm looking for the starter relay- I am going to try to clean the contacts b/c my car won't start. I think it's the starter. Is there any good way to isolate the relay?
Old Oct 10, 2005 | 07:13 AM
Audi2ptzero's Avatar
Elder Member
What happens when you try to start the car?
Old Oct 10, 2005 | 10:31 AM
Default Nothing...
Two days ago, when I started it, it sounded slow, like a dead battery. Yesterday, I went to start it and it wouldn't even turn. While I am cranking the interior does not get dim (i.e. no apparent load on the battery). I am guessing it's either the starter or the starter relay because I am not hearing a "click" when I turn the key- the car acts like it's starting, but no click and no sound from the engine bay. The "Press Clutch Pedal to Start Car" disappears from the display.
Old Oct 10, 2005 | 10:49 AM
Could it be the solenoid, or is that built into the relay?
Old Oct 10, 2005 | 06:12 PM
David.Norton's Avatar
Default Part of the solenoid...
by the by the ignition switch is a weak point on our cars, you might check it first.
Old Oct 11, 2005 | 03:03 AM
Default How do I get in there?
Is that behind the driver's knee bar, or does the instrument cluster have to come out?
Old Oct 11, 2005 | 05:56 PM
Default Tried to jump the car. no dice.
Car would not start-The engine wouldn't turn over. No pull on the battery. Is there a good way to isolate the starter or relay (Or solenoid)?
Old Nov 30, 2005 | 06:21 AM
texasQuattro's Avatar
New Member
Did you get this problem solved? I'm having a similar problem now. what were your symptoms?
 Pouria Savadkouei
 Michael S. Palmer
Jester34x
Sep 29, 2011 11:18 PM
Audi4000Bob
Jul 21, 2009 07:24 PM
JPCady
10
Feb 14, 2005 03:27 PM
rbuckstar
Dec 22, 2003 05:23 AM
gateway
Nov 16, 2003 05:15 PM
