Help, my brakes are doing something wierd....
Old Oct 10, 2005 | 09:32 AM
redridingchic's Avatar
New Member
Default Help, my brakes are doing something wierd....
Just before I come to a complete stop, right when I ease off the brake pedal a bit so I don't lurch to a halt, my anti-locks kick in. It only happens for a second, the pedal softens and vibrates, there is that characteristic humming noise, and then everything is normal again. There doesn't seem to be any specific road condition that brings it on. I don't think its any kind of a safety issue, but it sure is annoying and I'd like to fix it.
Can someone suggest what I should do to stop this from happening? Thanks! :0)
Old Oct 10, 2005 | 09:37 AM
BSK auf Arbeit's Avatar
FAQ Author
low on pads? my old 100 used to do that before i changed the worn down brakepads
Old Oct 10, 2005 | 09:38 AM
RallyVermont's Avatar
Mr Mc Feely
Default I would have the shop look into that, I had a major accident with my 5000cs...
The abs had the same symptoms as yours, and a few thousand miles down the road the drivers side brakes locked up under normal braking and I did a one wheel power slide off the road into some nasty trees. Def get is looked at for your safety.
Cheers,
Joel
Old Oct 10, 2005 | 09:45 AM
odelay12v's Avatar
Default mine did that when the abs unit went out the noise you head was ..
the abs kicking in thinking it was slipping..get it vages and check the codes
New Member
Pads were just looked at, they are in good shape.
Old Oct 10, 2005 | 09:46 AM
FAQ Author
get a vag com and run some codes
Old Oct 10, 2005 | 09:47 AM
New Member
Thanks Joel! I'll definitely get it looked into.
Old Oct 10, 2005 | 09:48 AM
New Member
Can Vag tell me if the sensors are bad?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 10, 2005 | 09:53 AM
S4iowa's Avatar
AudiWorld Expert
Default If the sensor is bad, it should have the ABS light on the dash and the Brake light flashing
But VAG-COM will tell you what sensor is bad if you have one.
Old Oct 10, 2005 | 09:55 AM
New Member
Default Someone also told me the sensor could be dirty.....
If it's dirty, will the vag tell me that too? If not, how hard is it to clean the sensors? If it's easy I might just do that to see if that is the problem.
