dad just called and the dealer told him on his 2.8 a4 that his inner tierods are shot
Old Oct 10, 2005 | 10:53 AM
odelay12v's Avatar
Default dad just called and the dealer told him on his 2.8 a4 that his inner tierods are shot
and that they wanted 490 to replace i have replaced a tie tod end and a tie rod on my a4 but not sure exactly what they mean the inner tie rod is anyone??? thanks hes hoping i can save him $400 plus they said the cvboot is torn for $290 and the brakes are bad.. i can do the lower two for sure..
Old Oct 10, 2005 | 11:01 AM
qfrog@work's Avatar
Senior Member
4b0-419-801-e (2)
Old Oct 10, 2005 | 11:02 AM
odelay12v's Avatar
Default is that the same thing as the tie rod assembly ?
when they say tie rod assembly it includes the inner and outer right..?? thanks
Old Oct 10, 2005 | 11:15 AM
qfrog@work's Avatar
Senior Member
Default yep.
the outters come with the new inners.
Old Oct 10, 2005 | 11:18 AM
odelay12v's Avatar
Default great thanks phil thats what i thought but good to make sure first..
no *** uming here !! thanks they also said she needed a new driver side cvboot and new brakes.. doh guess i have a bit of work to do this week... time to have a day off at the office..
Old Oct 10, 2005 | 11:56 AM
Speedy72t's Avatar
Default doing the entire assembly is a lot more involved than just swapping an end.
If I'm remembering correctly you've got a good bit of DIY experience but you might consider just taking the car to a decent alignment shop for the work. There is zero reason to do this at the dealer but a good indy will probably be half of what the dealer wants and the car has to be aligned anyway.
The rest of it you can knock out no problem.
Old Oct 10, 2005 | 12:12 PM
odelay12v's Avatar
Default i have actually done an entire assembly before ..
and swaped a end or two or 3 but the dealer wouldnt do just the part and not the alignment since i was going to swap a couple other alignment parts at the same time.. i will take it to an alignment shop for an alignment once i am finnished.. now if only i can get mike at pure to answer his phone so i can order..
Old Oct 10, 2005 | 12:31 PM
Speedy72t's Avatar
Default well enjoy then.
I just did the "front end". All the arms, ends and wheel bearings. I wish the kit had come with the full tie rod instead of just the end.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 10, 2005 | 12:43 PM
odelay12v's Avatar
Default yeah when i did my 8 arms and ends the ends didnt even come in kits yet..
so i had to order it seperately.. my fav part though if the pinch bolt.
Old Oct 10, 2005 | 12:45 PM
odelay12v's Avatar
Default what did you use for your wheel bearing?
did you use a hub shark type device or a machine press? so far i always used the hub shark since i dont yet have a machine press..but that one cam be a pain too..
