Where is Kombi valve (EGR) on 2.8Q 30v
Old Oct 10, 2005 | 09:48 PM
JJCNSX's Avatar
New Member
Default Where is Kombi valve (EGR) on 2.8Q 30v
<center><img src="http://pictureposter.audiworld.com/74141/img_1539.jpg"></center><p>hi all,
I was told to check the vaccum/kombi valves for code 16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
I am not 100% sure which ones to check (mine is 98 2.8Q 30V), i think the kombi valves are the "square looking boxes"... I did notice some of the hoses from/to "square boxes" are "crunchy".... is that right? But, i am not sure if they are leaking or not.. If i should replace them all, please let me know what size should i use....
Please help.. Thanks in advance..
-jjc.
Old Oct 11, 2005 | 04:21 AM
4Rings::G2 boosted::'s Avatar
Banned
The combi valves are on the back of each valve cover
Old Oct 11, 2005 | 06:10 AM
JJCNSX's Avatar
New Member
Default so, you cannot see them from the foto here?
if so, can you please circle them or post picture of them?
from bentley repair manual, it does seem like the 2 square boxes are komi valves though..
thx..
-jjc.
Old Oct 11, 2005 | 06:54 AM
Banned
Default No, they are not visible in this pic. The square boxes are the sec. air solenoid and the
variable intake solenoid
Old Oct 11, 2005 | 07:15 AM
j31izzle's Avatar
Default it should be right behind that little box. it kinda looks like an oversize fuel press. regulator...
that's in the pic on the right.
alen
Old Oct 11, 2005 | 07:29 AM
Banned
Default Here's what it looks like, one per side
<center><img src="http://www.squarewave.com/army/andrew/ttStuff/serpBelt-008.jpg"></center><p>
and here's the location diagram (#3 and #8):
<img src="http://pictureposter.audiworld.com/80906/secondary_air_inj.jpg">
Old Oct 11, 2005 | 07:53 AM
JJCNSX's Avatar
New Member
Default thank you so much!!
Would i have the access to all the Kombi vaccum hoses without having to remove a lot of engine parts?
What size of the hose are they? and how many each? can i get them from Dealership, P/N?
Once again, thank you all for speedy replies.
-jjc.
Old Oct 11, 2005 | 08:53 AM
Banned
Default you can trace the hoses coming off the left solenoid
They are partly hard plastic and partly standard vacuum hose you can get in any autoparts store.
 Pouria Savadkouei
 Michael S. Palmer
geoff
Jun 21, 2002 11:00 AM
triode
May 26, 2001 11:38 AM
Todd/A.W.E.
Nov 22, 2000 08:09 AM
Dauner
Jun 2, 2000 12:18 PM
