Headlights "shorting" out
Old Oct 11, 2005 | 07:04 AM
DudeDah's Avatar
Default Headlights "shorting" out
Hello all. I have a problem with my headlight "switch". When I push the lever up the lights do NOT come on any more. I have to push the lever up then forward really hard to get the lights to come on. After a while they will stay on, but it's obviously very frustrating. Has anyone had a similar problem? I noticed that the stalk has the cruise control lever attached. Do I need to replace this whole unit? Will this fix my cruise as well (the electrical contact cleaner fix lasted...oh a couple days)? Thanks guys...and gals, if any.
Old Oct 11, 2005 | 07:06 AM
Sal R.'s Avatar
Default Either replace the switch or take it apart and clean the contact points.
Common problem.
Old Oct 11, 2005 | 07:11 AM
Joey T
Guest
Posts: n/a
Default I wish we had a FAQ.
That would be great.
Old Oct 11, 2005 | 12:15 PM
michael-stanton's Avatar
Member
Default Re: Headlights "shorting" out
The headlight switch and the turn signal stalk are one unit - you'll have to replace them both. Since the cruise control lever is on the turn signal stalk, this means you're going to replace that as well.
Conclusion: If the fault is with the switch in both cases, replacing the stalk will fix them all.
vdubbin099
May 3, 2010 08:48 AM
Daltron
Mar 30, 2009 03:37 PM
mawallet
May 9, 2006 02:03 PM
Blake@NWAutoSalon
Jul 25, 2005 08:47 PM
badrunner
Feb 23, 2005 09:27 PM
